Old 08-27-2006, 06:34 PM   #1
Default TC tire degree question
I see touring car foam tires advertised a 0 degree and 2 degree. Is this referring to the tread surface being coned or what?
rollover is offline   Reply With Quote
Old 08-27-2006, 07:13 PM   #2
Trader Rating: 15 (100%+)
It is only for the back tires only. They are talking about the Offset that the rim has. Some cars need differant offsets so the rim does not touch the top part of the rear hub. I don't think that Jaco sells a 2 deg offset rim anymore. They show them as a 0 offset but they are really 1 deg offset now. What car are you running?
THE DOCTOR is offline   Reply With Quote
Old 08-27-2006, 08:20 PM   #3
Serpent 710. So if I understand correctly the wheel has a larger inside diameter on the inboard side.
Old 08-27-2006, 08:51 PM   #4
wallyedmonds's Avatar
its front and rear wheels, its the dish of the wheel
wallyedmonds is offline   Reply With Quote
Old 08-27-2006, 09:03 PM   #5
I didn't know that the fronts have differant offsets. Thanks, I will have to pay closer attention when I get fronts.
I am not sure what offset the 710 needs. You can ask on the 710 thread.
You can put 2 deg offset tires on any car but if the car was not designed to take them your car will be to wide.
Old 08-27-2006, 09:13 PM   #6
i think most cars can run 0 to 1 now you just change the tracking on the car i have a mtx 4 and i run 1mm offset .and some guys runin the rrr and 720 are runin 0 to 1,i dont think anyone makes 2mm offset anymore cuz the grp thing.
Old 08-28-2006, 01:59 PM   #7
duneland's Avatar
The problem is tire manufacturers have gone psycho on us! Referring to offset in degrees! What's up with that anyway? There is no angle or temperature in reference, so stop with the degrees already!
duneland is offline   Reply With Quote
Old 08-28-2006, 06:16 PM   #8
degrees is a measurement of the center (where you bolt the wheel on) to the outside of the rim,its the dish, and its done on real cars to
Tire Question. OG RC 10T Electric Off-Road 6 01-02-2008 11:11 AM
4 WD tire question Michal101 Electric Off-Road 23 04-29-2007 06:01 AM
Trade T2 2 degree front caster alum blocks for 4 degree straightaway R/C Items: For Sale/Trade 0 01-28-2007 01:01 PM
Jaco Nitro Shoes 16 pairs(front 0 degree, Rear 2 Degree offset) EJRacer R/C Items: For Sale/Trade 0 04-03-2006 01:13 PM
tire question zachzachz Rookie Zone 12 08-20-2003 02:21 PM
