Old 08-24-2006, 09:31 AM   #1
Rootman17's Avatar
Gear Selection
I need help with gearing my car. I am currently running 50T, 54T spur gears, and 20T, 24T pinion gears. I have good top end speed, but need some better off the line acceleration. Can anyone help me with my senario or help me understand what it would do if I put a larger or smaller gear in. Any or all help will be greatly appreciated. By the way I have a tamiya tg10-mk.2, but I believe the principles will apply to any car.
Rootman17 is offline   Reply With Quote
Old 08-24-2006, 09:40 AM   #2
fritzD's Avatar
Send a message via Yahoo to fritzD
i you want more acceleration decrease pinio teeth and increase spur teeth. This will, however, have lesser top speed. If you want more top speed do the opposite, more pinion teeth and lessert spur teeth. Final Drive Ratio = (# spur teeth/#pinion teeth) x internal drive ration
fritzD is offline   Reply With Quote
Old 08-24-2006, 09:44 AM   #3
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
Try to use 50T/56T spur gears, and 24T/18T pinions. You'll get quicker acceleration.
FREELANCE_RCer is offline   Reply With Quote
Old 08-24-2006, 11:19 AM   #4
Rootman17's Avatar
So if I decrease the pinion gear/increase spur gear for more off the line acceleration, this really shouldn't effect my top end speed because that will be in second gear. Just the top end in the first gear. Right?
How do you determine internal drive ratio?
Old 08-24-2006, 11:41 AM   #5
Trader Rating: 15 (100%+)
Usualy changing one tooth on the pinion is like changing two teeth on a spur. I would try just changing one tooth on the pinion first. One tooth on the pinion should be a noticeable change. You also don't want a huge change when it shifts from first to second gear. Your engine might not like it very much.
THE DOCTOR is offline   Reply With Quote
Old 08-24-2006, 11:44 AM   #6
asw7576's Avatar
To increase acceleration : Smaller Pinion and/or bigger Spur
To increase top speed : Bigger Pinion and/or smaller Spur
Changing Pinions have more effect than spur ( maybe twice the effect ).
Another thing to check is centax spring, clutch shoe, spring tension.
I need some help with my selection ModmannLevi Electric On-Road 2 06-05-2008 08:05 PM
Car Selection Help Topher Australian Racing 20 04-19-2005 10:10 AM
rim selection beetlebz Electric Off-Road 2 09-01-2004 10:52 PM
Help with Car Selection.... jhigga15 Nitro On-Road 20 05-19-2004 06:00 PM
TC3 Spur Gear Selection 48 pitch Cain Electric On-Road 8 05-04-2004 12:24 PM
