Old 08-14-2006, 01:04 PM   #1
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Default Someone is eating my tyres away.
I've got a problem where chunks of foam is being ripped of the rims on both my left and right rear tyres. I've tried different brands/shores.
Is this my driving style or car setup that causes this problem.
ProE is offline   Reply With Quote
Old 08-14-2006, 01:13 PM   #2
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Been hitting any walls?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-14-2006, 01:21 PM   #3
ProE's Avatar
O Yes. Always.
Our track has plastic tubing as walls. Not really hard and dont come near the wheels. I have this problem when I stay away from the walls as well.
Old 08-14-2006, 02:37 PM   #4
duneland's Avatar
Comes from hitting stuff. Remedy -- Don't hit stuff! Cracked asphalt can also cause chunking.
duneland is offline   Reply With Quote
Old 08-14-2006, 03:00 PM   #5
Rapid Roy's Avatar
It can also happen from simply flipping your car too. Its commonly called "chunking" your tires. You can glue a bit of foam in and true the patch back even with the tire. You can also apply a thin film of CA or shoe goo to the outer edge of the foam. Some foams come with a sidewall sticker too. The 1/8 scale tire have a "tire saver" that protects the sidewall, but I have never seen them for touring car tires.
Rapid Roy is offline   Reply With Quote
Old 08-14-2006, 03:28 PM   #6
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
double post, dont know how that happened, sorry
-Zac
Z.Hallett is offline   Reply With Quote
Old 08-14-2006, 03:28 PM   #7
Z.Hallett's Avatar
to me that looks like a "body tuck chunk". this happens when the wheel wells arent cut large enough, so when you get hit, take axial load(i.e. turning), or whenever the body moves around, the body doesnt have enough clearence to return to a normal position without hitting the tire. so it rubs and can make a tire look like a "normal" chunk.
-Zac
Old 08-14-2006, 03:45 PM   #8
wallyedmonds's Avatar
EVERY ONE DOS THIS FROM TIME TO TIME BUT IN TIME YOU WILL DRIVE BETTER AND YOU WONT CHUNCK AS MUCH AND IT WILL FELL GREAT NO MATER WHAT PLACE YOU FINISH.1/12 IS THE WORST FOR THIS.
wallyedmonds is offline   Reply With Quote
Old 08-14-2006, 05:21 PM   #9
Talking
wally my kar fells like durth
Gervais is offline   Reply With Quote
Old 08-14-2006, 11:12 PM   #10
itchy b's Avatar
O Yes. Always.
when truing your tyres, try rounding off the outside edge as i found that this helps to stop chunking a lot.
oh, and not hitting stuff helps too
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-15-2006, 07:03 AM   #11
hav_lova's Avatar
I always glue the sidewalls on my rear nitro tyres and it usually saves my tyres from chunking or if you have acess to a tyre truer try cutting them down smaller, this can help prevent chunking
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 08-15-2006, 09:17 AM   #12
ProE's Avatar
Its good to see that im not the only one with this problem.
Now, I have a major concern. It seems that to many people knows my driving style. and you havent even seen me on the track . (flipping,hitting stuff).
Well, now I know what the problem is, better start working on my driving then.
Old 08-15-2006, 05:57 PM   #13
rounding the out side edges of the tires will help stop the chunking
jake alton is offline   Reply With Quote
Old 08-16-2006, 05:09 AM   #14
itchy b's Avatar
soft foam + hitting stuff = chuncks
soft foams + not hitting stuff = no chuncks
it may look good when your car is flying through the air but its not good for your tyres
EX1.5-SC10 4x4
Old 08-16-2006, 10:28 AM   #15
if you decide to glue the outside edge of the tires, it makes the sidewall stiffer and the tire will act like a harder shore. you might have to make some adjustments to compensate.
sedanaddict is offline   Reply With Quote
Help...My LCD SD is eating gears. chumanji Electric On-Road 2 05-16-2007 10:29 AM
T-Maxx 3.3 eating Spur gears Pokerman11 Monster Trucks 16 08-05-2006 04:42 AM
my t-max is eating my savage X bigD270 Monster Trucks 67 03-31-2006 06:54 AM
HELP! My NSR12S5 is eating pistons! jasoncsc Onroad Nitro Engine Zone 8 04-19-2004 11:57 AM
os tr eating plugs sbmon Nitro On-Road 7 01-13-2004 11:15 AM
