Old 01-26-2003, 06:40 AM   #1
Send a message via ICQ to Cartman
Help ! how can this happen?
setting up a friends Kyosho landmax i think, 1/8th scale rally car with a pull start.
somtimes when it runs it goes backwards. how? i had smoke out the exhaust the pull start will not let the engine go backwards but it drove backwards. switch it off and restart its ok!!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 01-26-2003, 07:17 AM   #2
I know that somtimes an airplane engine will start backwards something to do with backfiring but I have never heard of it happing to a car engine maybe your carb settings are causing it to load up?????
FASTERTHENU is offline   Reply With Quote
Old 01-26-2003, 09:31 AM   #3
nova racer's Avatar
nova racer is offline   Reply With Quote
Old 01-26-2003, 11:54 AM   #4
i think that what is happening is caused by preigniting of fuel mixture
as piston is coming up it fires too early and shoots piston down before it gets to the top
try a different plug that is colder another head shim and check needle settings
jason102276 is offline   Reply With Quote
Old 01-26-2003, 12:00 PM   #5
How can the engine run backwards the pull start would lock up!!
Old 01-26-2003, 12:05 PM   #6
good point
does it always run backwards?
i put the diffs in my storm in wrong before and it went backwards could that be the problem
Old 01-26-2003, 12:10 PM   #7
no if i stop it and restart it its ok goes forwards!!!
Old 01-26-2003, 12:13 PM   #8
thats bizarre
i think it may be time to pull engine out and start checking the pullstarter
Anyone ever have this happen? itspat Monster Trucks 2 02-06-2007 02:05 AM
What has happen while Ive been gone? cdan2031 Electric On-Road 0 12-23-2005 11:00 PM
How did this happen? Team Duratrax Chat Lounge 16 12-18-2005 06:44 PM
The End. What do you think will happen? Scott S Chat Lounge 41 11-11-2005 02:40 PM
what will happen if I put a Aluma Electric On-Road 6 02-04-2003 03:11 PM
