( new to site ) also can i do this?
Hi, right now i currently have a GXR15 Pull Start Engine for my nitro rc car and i was wondering if it is possible to convert it to a non-pull start engine. I am saying like if i buy a new engine with no pull start will it still work?!?
Thanks,
Shaun
Thanks,
Shaun
post this question in the newbie,or nitro thread and you will get answers.
I moved this to the nitro forum, you should get a better responce here.
Are you looking to convert your GXR15 ( thats a Kyosho engine, right? ) to non-pull start, or are you looking to mount a non-pull start engine in place of your GXR15? Also, what car is it in?
Generally, with many nitro engines - yes you can convert it to non-pull start by buying a new backing plate and becoming creative with a cut-off wheel. There is a lot more to this process than what I am going to type here, as I'm not sure what exactly you want to do. I would probably reccomend getting a new engine rather than going through this process, even more so if you've run quite a bit of fuel through it. And again, generally speaking, most nitro cars you can mount a non-pull start engine in place of a pull start engine. You will have to buy a starter box though. It would also be best to purchase non-pull engine mounts and flywheel to lower the engine - which although not "nessisary" - is definately reccomended as a lower Center of Gravity is one of the benifits of a non-PS engine.
These additional questions should help get the ball rolling on getting you an answer. Welcome to RCTech!
yes i am trying to covert it to a non pull start it is a brand new kyosho engine in a FW-05T , any tips on how to convert do i just buy a adapter ( backplate ) or what?
You can convert your old engine to non pull or get a new engine without a pull start. Once you do this, you need to get a starter box or a bump starter in order to start the car. I wouldn't really recomend converting a pull start engine to non pull start. Its just better to get a new non pull start engine when your old engine wears out.
thanks rapid roy
I know that the magazines have done a "how to" on this before. Although I do not have any specific magazines or issues on hand to refferance for you. Let me warn you that it does take some dremel work, and if you haven't torn apart a nitro engine before - it's probably not something I would reccomend. I would rather see you beat the living tar out of your PS engine and then buying a non-ps than to accidently screw up your PS engine trying to convert it. However, I don't know how much experiance you have - thats for you to judge.
Beyond that - IF Kyosho offers the parts to do this ( im not familiar with their engines ) - you would need a new backplate for the engine, non-ps engine mounts, and non-ps flywheel. You would need a dremel and cut off wheel to remove the PS nub off the crankshaft.
