Old 11-01-2001, 05:37 PM   #1
Default V-one-S question
Hi, guys..
I am about to begin building my new V-one-S.
since its my first true kit..
Do I need anything before I start , other than radio/fuel and paint and glue for tires..
thanks..
What do you fellows recomend for hop-ups.. (my mate is going to HK and I might as well get it now)
PeNT is offline   Reply With Quote
Old 11-01-2001, 05:39 PM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: V-one-S question
Originally posted by PeNT
Hi, guys..
thanks..
we have tons of hop ups available here, Hong Kong.
Graphite deck, lightened shafts, alloy wheel adaptors are a must.
Manticore is offline   Reply With Quote
Old 11-02-2001, 04:26 AM   #3
opel92's Avatar
Hudy Gauge (For set-up of vehicle) or a good set of vernier calipers....... it's a necessity for proper setup so that u don't drive yourself insane in the chase for handling..... Good tools (Hex wrench for screws etc) and a swaybar.....
opel92 is offline   Reply With Quote
Old 11-02-2001, 09:57 AM   #4
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
either Hudy set up station or the one made by Integy. The integy one is a lot cheaper and it does the job too! you can find the integy from www.speedtechrc.com
Ah10 is offline   Reply With Quote
Old 11-02-2001, 02:16 PM   #5
Mauler's Avatar
Send a message via ICQ to Mauler
Hey Pent! Got your V One R finally!! If I had the V One S, the first hop up I would go for is definitely the 2 speed! If you want to get the maximum speed out of the engine, I would say it is a must...! Moreover, it does not stress your engine at high ranges too!
The next thing would be another engine...but that'll be another story...
Keep us informed on your new baby eh....
Mauler is offline   Reply With Quote
Old 11-05-2001, 05:06 AM   #6
Thanks.. I will probably get the 2 speed..
Haven't had much time to build it yet..
The manual mentions using silcone oil on the diffs.. but its highlights it as opitional..
Hopefully have it finsihed b4 the weekend...
Old 11-05-2001, 05:18 AM   #7
Mauler's Avatar
Yeah...some people use graphite or even titanium grease... preferences...
Old 11-06-2001, 07:56 PM   #8
Crap.. I just used the grease that came with it plus some I some oil ( I think it was teflon oil)
Does anyone know the part numbers of the 2 speed for the V-oneS
I was looking at the this website
controlcentre.rctech.net and they have so many after market parts for vone/R/S
Are there any other weakness to the V-oneS..
brakes ?,etc
Should I get any other gears ??
I might as well get some good stuff.. while my mate is in HK
since I kysoho stuff is too expensive in Aus..
thanks..
whats a good tuned pipe to get for it..
Old 11-07-2001, 02:54 AM   #9
opel92's Avatar
Pipes are a weird thing.......... i have friends that run the genuine novarossi pipes, rb pipes etc and they are excellent but one of my mates has an eagle racing pipe and he swears that it's the business....... he has been racing for about 15 years so i guess he should be able to tell. I think that u should get what ever will provide u with what u need from it (good torque, high top end etc).........
Old 11-07-2001, 04:02 AM   #10
GKC
GKC's Avatar
Send a message via ICQ to GKC
I would recommend getting a better brake disc such as aftermarket ones from Square or K-Factory, also the disc brake hub upgrade from the plastic one is also necessary. As for the top deck, not so necessary, you might want to modify and change the stock fuel tank (air leak problem) to a better one such as the one the Mugen MTX is using. As for your diffs, try silicone oil 7000wt for front and 5000wt for the rear, your car will handle better than using grease. Shock oil and grease are too light. I have a V-One S too.
GKC is offline   Reply With Quote
Old 11-07-2001, 04:48 AM   #11
Wow,
thanks for the tips..
I think I will defn get the Brake Disc .
Is the brake hub the same as a brake rotor or brake cam ?
Is a belt tensioner required for the V-one S
thanks.. again
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
