RRR to 235
RRR to 235
Hi
Has anybody tried to convert an RRR to a 235 car? I know there was an attempt to do it with a Mugen. I would have thought it would be pretty easy and could be done with minimal bespoke engineering
Cheers
Cheers
Originally Posted by ziggy12345
Hi
Cheers
Cheers
Maybe I would check on 1/8 front and rear lower suspension. For eg. MRX3 rear lower suspension looks identical with MTX4 rear lower suspension
Hi
Cheers
Cheers
It is nothing but EASY to convert any current 200mm into the TRUE 235mm spec....including RRR, MTX3 or 4 or 710....I have seen MTX3 and 710 converted to 235mm, but definitely not EASY, and definitely not CHEAP...it is simply a hobby, experience or just the heck of it for those individual that has the tools and skills to mill out those custom parts and convert them in 235mm
Cheaper and easier way to do is....get a true 235mm like Serpent 835 or Mugen Advance (if you can still find it new..) or run 200mm with LOLA body with 5 -port engines in outlaw class.
Converting a RRR into 235mm....you will need quite a lot of Serpent or MUGEN parts along with tons of custom made items.
I love runing outlaw but in the UK its all but dead. The 235 class is still around but i don't want to go to a Serpent. I think it mighht be a easier option to try to get the outlaw class going rather than build my own 235 car
Cheers
Cheers
Why don't you ask your race organiser to open outlaw 200mm lola bodies with .12 engine limit ? The fun is the same.
Here is interesting idea: My race organiser is planning to open a fun race 3 x 45 minutes finals. No heats, just finals 3 times. Rolling start for 1st, 2nd, 3rd rounds.
We run local races but because there is no series everybody races touring shells. I'm trying to get a series going for next year
Driving a 235mm is very much a different experience then running a 200mm with LOLA body...............however, from the last several MWS races (outlaw class....235 or 200mm with 12 5 ports engine)........235 are not able to outrun 200mm with 5 ports anymore cause they are just smaller, turn faster and tighter and wiht 5 port 12 engine nowaday, they are faster too......
