Old 07-26-2006, 07:05 AM   #16
M7H
M7H's Avatar
Originally Posted by uniquexme
i have also noticed that RB Rody method of covering the heat sink with something (maybe like alum foil), can we use it together with cyrul method for the very 1st tank? would it be neccessary?
With the Cyrul methode, the engine is set so rich that it will not really heat up, I also use a towel to cover-up the cooling head......
During the very 1st start up of engine, do you guys' piston get stuck at the top of the sleeve/liner? coz i remember that last time when i break in my engine, it got stuck and i have to use the screw driver to dig on the flywheel to get it down. so if anyone could kindly share their recommendations here. thanks.
Always, ALWAYS first heat-up the engine with a hairdryer. Then you will not have any problem starting it on the start box......
Serpent
M7H is offline   Reply With Quote
Old 07-26-2006, 08:49 AM   #17
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
With the Cyrul methode will it be ok to heat with hot air while doing the first 3 tanks??
or would that over heat it
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 07-26-2006, 08:57 AM   #18
M7H
M7H's Avatar
It's better that the heat comes from inside the engine, and not from the outside, because then it will not break-in properly.
Serpent
Old 07-26-2006, 09:02 AM   #19
what percentage of fuel is used in break in and oil percentage??
Futaba
Mugen
Novarossi
Byron's
Old 07-26-2006, 03:20 PM   #20
M7H
M7H's Avatar
I use regular fuel, the same stuff as I race with.....
Serpent
Old 07-26-2006, 06:25 PM   #21
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
our track doesn't have power supply, so we can't use the hair dryer at all. hmm, i understand that using RB method of covering the heatsink with alum foil or tower will heat it up, but wat i meant is wat if it get stuck before u can start the engine? coz i reckon that by digging on the flywheel, we are forcing the piston down, so it might be this step that cause scratches on both piston and liner.
uniquexme is offline   Reply With Quote
Old 07-27-2006, 01:03 AM   #22
M7H
M7H's Avatar
Well, it's not the best for your engine, but it will survive.
But again, to avoid the piston to get stuck, heat it up...
If you don't have power on your local track, why don't you do the first part of the break-in at home?......
If you break-in the engine without heating it up, be very shure that you replace the conrod after break-in periode......
Serpent
Old 07-27-2006, 02:30 AM   #23
uniquexme's Avatar
hmm, true also, but one thing that i afraid is that the neighbour might complaint on the noice of idleing and WOT. kekeke.
Old 07-27-2006, 02:54 AM   #24
M7H
M7H's Avatar
Don't do it at night then.....
But, placing an additional cover, or something, over your exhaust, works as a noisereducer.....
Serpent
Old 07-27-2006, 06:17 PM   #25
uniquexme's Avatar
may i ask why is that the piston still got scratches mark in between the top and 2 groove lines of piston after following cyrul's WOT Break in ?
Old 07-27-2006, 06:44 PM   #26
wallyedmonds's Avatar
ya im just gona do my own runin thing, heat gun and two tanks on the box then on the track rich for two then start to lean it slowly
wallyedmonds is offline   Reply With Quote
engine break-in method..? rwlkr Electric Off-Road 15 03-24-2007 11:35 PM
Engine break in method kahuna2793 Electric Off-Road 8 05-10-2006 07:16 AM
Can someone explain to me this method of break-in? B.LaFrance Nitro On-Road 11 11-10-2005 06:44 AM
what break-in method 2ffu Onroad Nitro Engine Zone 2 12-20-2004 07:16 PM
best break-in method SalvadoriRacing Electric On-Road 1 01-24-2004 07:56 AM
