Old 05-27-2003, 04:04 PM   #1366
Motorman's Avatar
I guess they did better than I thought.
Final standings
1/10 200mm Sedan
1. Chris Rountree *
2. Al Guerra *
3. Philip Umino
4. Kyle Skidmore
5. Scott Rister *
6. Mike Walker
7. Larry Stone
8. Polo Perez
9. Mike Swauger
10. Larry Pryor
11. Jimmy Huynh
Right on guys way to rough em up.
P.S. None of those guys drive for me directly, they just had horsepower, tires and a lot of skill. Their just guys that can put the power I make on the ground effectively.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 05-27-2003, 05:46 PM   #1367
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Motorman- What plugs do you want us to use in the RTU's? And I'm running in a NTC3(I know I know.... Mugen forever) and I'm getting an RD Logics pipe. I'm just wondering which you would get Turbo or Standard? I'm not worried about legal so I'm leaning towards the Turbo. Any advice greatly appreciated.
Jon
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 05-27-2003, 09:40 PM   #1368
NitroNut's Avatar
motorman how do i fix a engine that has too much compression for a starter box to start it??? or ne one
NitroNut is offline   Reply With Quote
Old 05-27-2003, 10:20 PM   #1369
Send a message via AIM to Bryan N.
The Odonnell seem to run good with the RTU's and go with the Turbo Rd pipe.
Bryan N. is offline   Reply With Quote
Old 05-27-2003, 11:04 PM   #1370
InitialD's Avatar
Before starting, lube the piston / sleeve with a little after run oil. Make sure the piston is at the BDC position before you strat the engine. Easier to crank. Also, loosen the plug a little before starting and tighten it back once you get the engine running.
And yes, remember to make sure that the piston goes back to BDC position once the engine dies. You wouldn't want the engine to cool down when the piston is at the top of the sleeve where it is the tightest.
Old 05-31-2003, 12:09 AM   #1371
EdwardN's Avatar
Default Re: Carb Needles & Venturis...
Originally posted by InitialD
I don't know if this will get answered but has anybody given any thought about making the venturi of the spray bar having smaller diameter with the opposite needle also smaller in the same proportions?
I think this will create a better and finer spray pattern of the fuel and most importantly better fuel economy...
I think in this case better fuel economy does not equal less performance... In fact I think you will get better performance since a finer fuel spray pattern will make for a better air fuel mixture... Just a thought.
To run engine you need some volume of mixture. If you will decrease size of fuel supplying ventury (regardless needl) it will bring your engine performance dramaticly down the same as you put your carb on idle- fuel-air constant proportion)! We tryed to put 9 mm ventury for air and engine automaticly was asking reacher set up-was encrease of power (do not cross reasonble limit). there is no difference increase air ventury or decrease fuel ventury! the ratio air-fuel will be constant ( reasonble ) I think you will not find anything to do it!
EdwardN is offline   Reply With Quote
Old 05-31-2003, 05:32 AM   #1372
Jon
I'm running Novarossi #6 or #7 plugs with Odonnell 30% in my RTUs with the RD Logics inline Turbo pipe..It's UNBELIEVABLE!!!!
tekrsq is offline   Reply With Quote
Old 05-31-2003, 05:44 AM   #1373
THeGame's Avatar
Send a message via AIM to THeGame
Motorman are you still doing Motors at all for the public ?
THeGame is offline   Reply With Quote
Old 05-31-2003, 08:35 AM   #1374
I don't thnk he is. I've had my engines for a while.
Old 05-31-2003, 01:16 PM   #1375
Talking Hey Motorman remember doing this baby?
Look here!
What an excellent job you did! Now if I can just find some fuel for it! Or maybe I'll just keep using it as a paper weight!
Dookiestick is offline   Reply With Quote
Old 05-31-2003, 11:24 PM   #1376
EdwardN's Avatar
Default Re: Hey Motorman remember doing this baby?
Originally posted by Dookiestick
Look here!
Comercialized toy! I vote for paper weight! Ask me why!
Old 06-01-2003, 02:06 AM   #1377
Old Skool's Avatar
Correct me if I'm wrong, but doesn't fuel stick to polished surfaces? I would think that you might want some internal surfaces to have a polarized or satin finish?
Old Skool is offline   Reply With Quote
Old 06-01-2003, 02:15 AM   #1378
WHY?
Old 06-01-2003, 04:26 AM   #1379
Taylor-Racing's Avatar
Default Re: Re: Hey Motorman remember doing this baby?
Hmmm . . . you're being a bit unnecessary here, Top Gun.
By the way, there are two "m's" in "commercialized".
And if Dennis makes a few dollars out of them, then you're strictly correct, it's commercial.
And "toy" . . . gee, there all toys.
I don't know Dennis, personally, but there seems to be a lot of people here that speak highly of his work.
. . . and I haven't seen a lot of people running your engines.
. . so I won't ask you "why", but I will ask you to put one of your engines up against this "commercialised toy".
Given that I'm on the other side of the planet, I would like to call for volunteers to witness this event - any takers, please?
Taylor-Racing is offline   Reply With Quote
Old 06-01-2003, 06:51 AM   #1380
Motorman's Avatar
yes it does, it is done that way intentionally, I want it to stick!!!!!!
Dookie's, comment was not negative. DUH read it again.
I will stack my motors against anything anyone can make, they win races time and time again, they are all the same contrary to popular belief. there is no special team engine.
That is my signature work, How much of that work do you see in other tuners engines. ?????
777 I really don't care what your opinion is, bring it to the track and show me.
I am working on something new for the public, to be disclosed in the near future.
Cam modified motors (3) crazymechmow R/C Items: For Sale/Trade 12 01-15-2006 02:50 PM
FS: Modified motors (7T, 9T) WeatherB R/C Items: For Sale/Trade 10 09-21-2005 06:56 AM
FS: 3 Richey / Collari modified motors ChrisF R/C Items: For Sale/Trade 3 12-13-2003 06:03 PM
FS: Richey Modified motors ChrisF R/C Items: For Sale/Trade 0 08-28-2003 10:22 AM
dennis richey motors for sale dg8one R/C Items: For Sale/Trade 13 12-10-2002 06:21 PM
