Old 01-07-2002, 02:36 PM   #121
No doubt, I'm still learning. So far it seems most of the improvment I've seen is in much higher rpm. Maybe I shouldnt have said "all" you get from a dremel is RPM (misspeak?). I assumed I wouldnt see NOVA type torque, so went to a 13
tooth 1st gear. That seemed to let me run the twisties with the big boys, sometimes passing them.
Just got the new Rc nitro mag in the store, the GT-4R is reviewed, wth a RTU MT12.
Foger Rox is offline   Reply With Quote
Old 01-07-2002, 04:23 PM   #122
Motorman's Avatar
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 01-07-2002, 06:05 PM   #123
MM, LOL, no biggie. And I'm definitely not you, If I came across "too" hot I'm sorry. Didnt mean to poke ya in the eye, LOL. I've "modded" 3 Ofna colt 12s. Sum total of my experience. Was made manager at the Local General hobby shop about 20 months ago, and had to learn a bunch, quickly (trains, plastic models, nitro cars). So I've been into nitro for just under 2 years. A 44 year old "newbie". 2002 will be my 1st year to really spend some time at the local tracks.
The Rc Nitro is March 2002, they cover the "stock" Mt12 too, in a separate article.
Do you mean your MT12 will rip up Ofna spurs? He he, cool. My Racer 2 was my 1st car (a drag car), has Ofnas big 15, 8 port in it. Over a horse no doubt, its never torn up a spur (Ofna). Ahh man, I just dont have the bucks yet.
Old 01-07-2002, 06:34 PM   #124
Motorman's Avatar
Old 01-07-2002, 06:59 PM   #125
Originally posted by Motorman
(multiple failures)
MM, Oh jeese! They came out with the clutch type 2spd too late for him.
The Gt-4s & Reflexs make my OB4 look old, snif. I've been running 5 apart with a slightly later shift, Ob4: 13-18, 45-41. On big Parking lot tracks. 200 ft plus straight aways. Seems like most guys are running 4 apart, eh? DO you do up big 15s for onroads too right? Opps, there goes all my Hobby $$ for 2002.
Thanks for the info.
Old 01-07-2002, 07:24 PM   #126
Motorman's Avatar
Old 01-08-2002, 03:14 PM   #127
AMGRacer's Avatar
Motorman, you were saying on the HPI forum that most cars are overgeared for the RS12. What gearing would you recommend for a Mugen MTX2 using a RS12?
AMGRacer is offline   Reply With Quote
Old 01-08-2002, 07:06 PM   #128
Motorman's Avatar
Old 01-08-2002, 08:12 PM   #129
AMGRacer's Avatar
Ummmmm, wow. I dont quite get all of the info you gave me, but I will sit down and think it through after work. Wow.
I have a MTX and a V1R so I a trying to work this through but it appears that you are saying to go less teeth on the pinion to compensate for a lack of low down torque, and to keep the top speed down to a manageable level? Because the RS12 pulls so much more RPM it can be as fast at lower pinion count, and actually needs to to make up for lack of low end torque?
And the clutch engagement point needs to be very high as it does not pull well enough on low RPM?
OK thanks for all the info, need to think it thru
Old 01-08-2002, 08:29 PM   #130
Motorman's Avatar
Old 01-08-2002, 08:55 PM   #131
AMGRacer's Avatar
As usual you have elevated me to a new level of understanding I have to this point be an install engine/install standard clutch and pinions and tune chassis guy. What you just outlined makes perfect sense yet I never even considered it before
I like your idea about bringing the pinion difference closer due to trying to reduce the RPM drop in the 1-2 change because of the narrow RS12 powerband. Funny thing is I spent a fortune on my 1:1 car gearbox for a close ratio cog set but it never occured to me in my RC *slaps head*
Old 01-08-2002, 09:45 PM   #132
Motorman's Avatar
Old 01-08-2002, 10:14 PM   #133
AMGRacer's Avatar
Wow that thing is almost as light as my 1/10th. I have to reduce the weight in my drivetrain yet as well! I am too busy racing to mess with the car too much
I am kinda nervous of my RS12 now, hope it goes OK. I might have to get one of your 16% IFMAR specials if it does not work out so well
Old 01-08-2002, 10:57 PM   #134
got_speed?'s Avatar
Motorman,
I installed an RB X12T on my Impulse, I have about 10 tanks on it, on my way to leaning it out I get a midrange choke... I know I dont have it tooo lean because after it chokes it revs up with alot of smoke.....the temp is about 160 F...Hope you can shed some light
got_speed? is offline   Reply With Quote
Old 01-08-2002, 11:08 PM   #135
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Originally posted by got_speed?
Motorman,
I installed an RB X12T on my Impulse, I have about 10 tanks on it, on my way to leaning it out I get a midrange choke... I know I dont have it tooo lean because after it chokes it revs up with alot of smoke.....the temp is about 160 C...Hope you can shed some light
My first thought is may be the engine is too rich and when the low to high transistion it just flooded the carb! may be try to lean it out a bit more and maintain around 190 see what happen!
Ah10 is offline   Reply With Quote
Cam modified motors (3) crazymechmow R/C Items: For Sale/Trade 12 01-15-2006 02:50 PM
FS: Modified motors (7T, 9T) WeatherB R/C Items: For Sale/Trade 10 09-21-2005 06:56 AM
FS: 3 Richey / Collari modified motors ChrisF R/C Items: For Sale/Trade 3 12-13-2003 06:03 PM
FS: Richey Modified motors ChrisF R/C Items: For Sale/Trade 0 08-28-2003 10:22 AM
dennis richey motors for sale dg8one R/C Items: For Sale/Trade 13 12-10-2002 06:21 PM
