Old 08-19-2002, 12:36 PM   #871
NTC3NUT's Avatar
Default Turbo/Non-Turbo
Dennis, I have a JP RS-12 TS1 turbo which I believe is a 3-port engine, correct? I would like to change the button to a non-turbo. Could you tell me what size head shims I should be using? Also, would this then make my engine ROAR legal? Thanks.
NTC3NUT is offline   Reply With Quote
Old 08-19-2002, 03:25 PM   #872
Motorman's Avatar
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 08-19-2002, 05:58 PM   #873
NTC3NUT's Avatar
Thanks for the info.. I have a few Mugen MT-12 non-turbo buttons, would they work? Also, how about the ROAR legality? By reading the rule book, as long as it's 4-ports or less with a non-turbo plug it should be ok.? Thanks again.
Old 08-19-2002, 07:45 PM   #874
Motorman's Avatar
Old 08-19-2002, 08:18 PM   #875
NTC3NUT's Avatar
Thanks for the info. Motorman. If you get back into public sales I'll be the first in line for an RTU.
Old 08-21-2002, 01:42 AM   #876
Send a message via ICQ to Cartman
Default Motorman advise please
Motorman what differance does the red bit JP puts in his engine (in the crank) make?
what does it do?
what is it?
i would be gratefull if you could reply as i know you are trying to get away from this sort of thing, but i know your THE BEST!!!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 08-21-2002, 06:08 AM   #877
che
che's Avatar
NTC3NUT
I have the same engine as you and wanted to do the same thing.
I just purchased a Hard Core Racing Mutant Head (blue).
It incorporates the cooling and button head in one piece.
It was a direct bolt on fit and it works perfectly. It also runs cooler as well!! I started in the spring with a MC59 plug and am now running an OS8.
Che
che is offline   Reply With Quote
Old 08-21-2002, 01:56 PM   #878
NTC3NUT's Avatar
Che, Thanks for the input. I have a few heads in my pit box including the Hardcore Mutant. I am gong to try the Kawahara Zac head I have with an extra Mugen button. I have had great success with a head made by Powerline. It's for the T-Maxx but it uses a button and bolts directly to a Nova Rossi based engine. I have them on both my Mugens with the stock button and it cut the temps by 30deg. +/-, no kidding. It doesn't look as good as the Hardcore head but it's $20. cheeper and it's 3 times as light. Thanks again for the input, I'll let you know how it goes. Also, I was curious, do you see any drop off in performance by changing the button? This engine is awesome as is and I'd hate to see it fall off.
Old 08-21-2002, 02:12 PM   #879
che
che's Avatar
I found the change made the engine easier to tune (for me).
So I actually got better performance out of it, but if it were to fall of due to a non-turbo plug, it can't be that much.
And if your new head allows it to run 30 degrees cooler, you will gain from that!
Old 08-21-2002, 11:32 PM   #880
nitrodude's Avatar
i have been rading this forum fr about 4 months and I finally have a question. Early in the year a got a MT12 with a head with 11 fins instead of nine, I was wondering what the difference is between this engine and the one with 9 fins. Also if you could tell me what the correct needle settings are as i have been having problems tuning the engine for the last couple of weeks.
Thanks in advance
nitrodude is offline   Reply With Quote
Old 08-22-2002, 12:47 AM   #881
rjl
rjl's Avatar
rjl is offline   Reply With Quote
Old 08-22-2002, 05:27 AM   #882
NTC3NUT's Avatar
Default MT-12
Nitrodude, My local hobby shop sells both the 9 & 11 fin MT-12. The only diff. is the head itself, and about $10.. If you still have your box take a look at the tag, it says "BIG HEAD".
Old 08-22-2002, 07:04 AM   #883
Default Re: MT-12
I thought the "big head" engines had a different stroke, also.
tekrsq is offline   Reply With Quote
Old 08-22-2002, 07:24 AM   #884
Default "Big Head" MT-12
The 11 fin head engine is the newer short rod engine and I have one. I have tried many pipes and had tuning nightmares, all to find out if you use an Associated pipe it works like a champ ! It pulls my old style (still same run time though) MT-12 from the bottom to the top and seems to have more top end power! Before the Associated pipe, I tried the stock Losi with my XXX-NT, a 1pc. Dynamite, X-12 (almost as good as Assoc.), and a Drake pipe, and they all made it bog down on bottom until it got the revs way up and it ran way hot with them. Hope this helps!
ronin8451 is offline   Reply With Quote
Old 08-22-2002, 03:01 PM   #885
NTC3NUT's Avatar
Default MT-12
I wasn't aware that the "BIG HEAD" engine was the new short stroke model (neither was my local hobby shop apparently). I've heard good & bad things about it on this website. I haven't run one, both of mine are the long stroke which are awesome. I guess it doesn't matter if it's good or bad, that's all you'll be able to get soon right? I am glad to hear it's running good for you. My only question would be, how will it run in a NTC3 with the only 2 pipes available?
Cam modified motors (3) crazymechmow R/C Items: For Sale/Trade 12 01-15-2006 02:50 PM
FS: Modified motors (7T, 9T) WeatherB R/C Items: For Sale/Trade 10 09-21-2005 06:56 AM
FS: 3 Richey / Collari modified motors ChrisF R/C Items: For Sale/Trade 3 12-13-2003 06:03 PM
FS: Richey Modified motors ChrisF R/C Items: For Sale/Trade 0 08-28-2003 10:22 AM
dennis richey motors for sale dg8one R/C Items: For Sale/Trade 13 12-10-2002 06:21 PM
