Old 07-15-2002, 07:27 PM   #751
Motorman's Avatar
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 07-15-2002, 08:21 PM   #752
JLMG1971's Avatar
Sorry for posting this again, don't mean to flood the forum but I please need and answer and some advice
Need Help
Does anyone know if AE has released the new tank? I am having lots of problems with my NTC3. I have purchased the car with a OS.12 TR more than 3 months ago, and haven't been able to finish a qualifier yet, much less a main, the problem is the engine keeps stalling, I figured the OS was the problem so I got a MT12, well after break in the engine does the same, it stalls. I have tryed diffefent settings, rich, lean, leaner, richer both needles, I even played with the middle range needle formthe MT12, etc.. and all the gurus from my club have tryed to help me but no improvement. The engine (both) always stall in the same spot, right after taking into the longest straight, when I hit full throttle, and eventually when taking a tight U-turn. It seems to get lean and stall. Two engines doing the same thing (both new) seems very uncommon. I though the gas tank had a leak so I replaced it with a new one, no luck, I have lenghtened and shortened the pressure line, did also the pressure fitting modification on the top of the lid but nothing, still the same problem. My hunch is the gas tank desing, any ideas?
Also, can anyone post the 3 needles factory settings for the MT-12, I have so much leaned and richened it that I don't know anymore where to start back again. Your answer will be very much appreciated.
JLMG1971 is offline   Reply With Quote
Old 07-15-2002, 08:27 PM   #753
Craig's Avatar
Send a message via AIM to Craig
Well it could be boiling.That would answer why the side exhaust doesn't seem to have problems.But to get a vapor lock you would have to low fuel pressure.And I believe thats not a problem right? But what if the fuel going in was close to the boiling point and upon enter the crank boiled.What would happen then? Try finding some higher oil fuel.Try something with 20% oil.That would help a little on cooling.How about the three shoe clutch? Does that slip? Personally I feel that its alittle too grabby.It doesnt seem to let the motor rev.It felt like it was bogging down a little.But it might help.
Dennis-Did you have a one way in the your car? They could cause a sheared front drive pinion.Usually it just breaks the Alum.CVDs,but if you have replaced them with steel ones I could see that as a possiblity.The Rulon bushing is designed to absorb some of the shock,but I think it needs to be oiled to allow that to happen.I know they don't say to but its just one of those feelings.
Also I think the car could use a solid carbon rod instead of the alum. driveshaft.It would provide a little bit of give.The video was taken my a guy that went with 2Fast.I see if he can convert it to a file and send it to you if you want.
Craig is offline   Reply With Quote
Old 07-15-2002, 08:31 PM   #754
Craig's Avatar
Which way does you fuel nipple on the carb point? I personally used 1.5 turn out on the lowend with the mid range flush with the body and the high around 2.5 to 3 turn out.That should get you in the ballpark,but someone else may have a better answer.
Old 07-15-2002, 08:48 PM   #755
Motorman's Avatar
Old 07-15-2002, 09:08 PM   #756
In December of this yearYokomo is releasing there new shaft driven car to replace the gt4 in Japan. Then 6 months after it is supposed to hit USA and Europe.
HiperRBx12 is offline   Reply With Quote
Old 07-15-2002, 09:12 PM   #757
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Dennis-
You are able to run the mugen tank dry with a rear exhaust engine or with a side exhaust engine?
Mike Webb
mike_Webb is offline   Reply With Quote
Old 07-15-2002, 09:24 PM   #758
dg8one's Avatar
Default motorman
hey dennis its nelly just let you know that my phone is connected again so just let me know if my motor is done.
can i use mc59 on you're motor or should i stick with mc9?
dg8one is offline   Reply With Quote
Old 07-15-2002, 10:20 PM   #759
Craig's Avatar
Dennis-What did you have to do to the three shoe clutch? I need it to not engage so hard.
Old 07-15-2002, 10:36 PM   #760
Regional Moderator
kansasracer's Avatar
Dennis:
Forward me your mail address and I'll send you a copy of the main.. I taped it for 2 fast cause I was "2slow" to be in that main...
I'll do it for a favor to be named later (kinda my godfather impression!!!)
kansasracer is offline   Reply With Quote
Old 07-16-2002, 01:45 AM   #761
InitialD's Avatar
Originally posted by kansasracer
Dennis:
Hi kansasracer, if you don't mind, could you put it up on some website that those who would be interested can download it? I'm sure I am Thanks.
Old 07-16-2002, 04:27 AM   #762
stefan's Avatar
Send a message via AIM to stefan
Default Dennis
I just put the Mugen clutch shoes and springs on my TC3 three shoe flywheel.
The only thing you need to do is dremel a second slot in the flywheel nut for the springs.
Otherwise, perfect match
stefan is offline   Reply With Quote
Old 07-16-2002, 04:54 AM   #763
Dennis, how well did you know Marty and John?
davidl is offline   Reply With Quote
Old 07-16-2002, 07:29 AM   #764
Regional Moderator
InitialD:
The video is in super 8 format right now. I don't have the computer hardware to load it up to a internet site. I would donate a copy of it to someone who has that capability (as long as they make it public...)
Anyone?
Old 07-16-2002, 09:08 AM   #765
rayhuang's Avatar
Default Part numbers!!!
If you guys have handy tha part numbers for the Mugen clutch shoes, Mugen Clutch springs and the Mugen Tank, I'd like it. I am trying to get some parts from a buddy who has raced his Mugen for years, but may need to order them from LHS!!!
I asked this on the NTC3 forum, but realize this is probably a better forum for this question. I have a STOCK spare Pipe and Manifold for the NTC3 Rear Exhaust. I am wondering how much to shorthe it for a ROAR legal 12 motor (NM SX12 RE EV1) to run on a track with long 200' back straight. I am using the copper clutch springs, but all else is stock (if that helps).
Thanks Mike and gang,
Ray
Cam modified motors (3) crazymechmow R/C Items: For Sale/Trade 12 01-15-2006 02:50 PM
FS: Modified motors (7T, 9T) WeatherB R/C Items: For Sale/Trade 10 09-21-2005 06:56 AM
FS: 3 Richey / Collari modified motors ChrisF R/C Items: For Sale/Trade 3 12-13-2003 06:03 PM
FS: Richey Modified motors ChrisF R/C Items: For Sale/Trade 0 08-28-2003 10:22 AM
dennis richey motors for sale dg8one R/C Items: For Sale/Trade 13 12-10-2002 06:21 PM
