Old 02-27-2002, 07:01 PM   #346
AMGRacer's Avatar
Originally posted by Motorman
Well I can tell you you won't get 8 not even close. 5:45 to 6:00 but then again if your up 2 to 3 laps each refill it won't matter will it. plan to gear down 2 teeth on first gear pinion and 1 on second pinion. The key on the RTO is not to lug the engine. It needs to rev very high with a loose clutch and a high shift point. The second gear slingshot will amaze you. Rev the hell out of it.
Hi Dennis. I have one of your engines (RTU serial 522) just after some info. I run 16% nitro, what head shimming do you recommend?
Also I run a V1R with an internal ratio of 2.58. My 1st gear final drive is 48/16 (3) giving final drive of 7.74 and 2nd gear is 5.40, are these near the ballpark figures you run on your Mugen?
When you say loose clutch you mean high engagment point? I have my Mugen centax set at 1.0mm on the adjuster nut with .5mm end float, any recommendations? You can PM me or answer me here whatever you prefer Thanks for your help!!
AMGRacer is offline   Reply With Quote
Old 02-27-2002, 08:37 PM   #347
Send a message via AIM to Kaliboy
Motorman: Actually, I was able to get just a tad over 7 minutes per tank. I was using 30% fuel. Since I was using the higher nitro, I was able to lean out the motor even more. With the 20% I didn't get much runtime. As for reliability guys...my first motor lasted over 3 tanks. The conrod bushing finally disintegrated which is usually expected. I'm sure it probably could have gone longer had I not been lazy to disassemble the engine and check the conrod bushing. The best part is that the motor really came to life after the 1st gallon. The first gallon was run on 20% and the rest on 30%. I can't wait for nitro season here. The only motor that I will run now is an RTU (probably the RTO this season)
Kaliboy is offline   Reply With Quote
Old 02-27-2002, 09:29 PM   #348
AMGRacer's Avatar
I think you mean 3 gallons here I actually got my RTU off Kaliboy almost brand new, and it was exactly as he claimed!! (Just thought I would give you some props man )
Old 02-28-2002, 01:24 AM   #349
Motorman: i have been there done that... i entered a MKII pureten in the pureten class, using a modified os cv-x engine, and i started from position 7, after the first lap i had about 6 meters down to the next guy(i was in the lead after a half lap..) it used a lot more fuel, but i didnt care, the other guys didnt have a chance anyway...)
the money is going into your account sometime today....
HFracing is offline   Reply With Quote
Old 03-01-2002, 04:28 AM   #350
Question for everyone: Has anyone used a "Buggy" cooling head for a sedan? Both RB and Novarossi have pictures on their respective sites. They appear to be normal heads just with a few more fins on top. Would the benifits be small in a sedan?
SHARP is offline   Reply With Quote
Old 03-01-2002, 01:23 PM   #351
Motorman's Avatar
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 03-01-2002, 06:43 PM   #352
Send a message via AIM to VinDollar Send a message via Yahoo to VinDollar
Default What the best exhaust??
To Motorman:
What is the best exhaust and header combo out there in your opinion for your 9 port eagle?? I'm looking to buy a pipe and header or a one piece for the engine. I'm running a mtx-2 geared 17/47 21/43 with a straight on my home track that is at least 175-200 ft. Thanks in advance.
Ps: I'm the guy that order the two 9 port eagles: sneaky:
VinDollar is offline   Reply With Quote
Old 03-01-2002, 09:44 PM   #353
raffaelli's Avatar
whew....package arrived!
raffaelli is offline   Reply With Quote
Old 03-02-2002, 09:53 AM   #354
Motorman's Avatar
Old 03-02-2002, 09:56 AM   #355
Motorman's Avatar
Old 03-02-2002, 11:25 AM   #356
Motorman's Avatar
Old 03-03-2002, 01:09 AM   #357
Send a message via AIM to Mr MTX
On that short of a track I wold use a milke or yokomo inline on the eagle. as for seperate pipe header combos use the Novamega 12 Ci pipe or the associated GT pipe. The eagle makes revs so you need a torque pipe to compliment it. plan to change the pinions to 15/18 with the biggest spurs
Those pinions huh? Would you say that the Eagle's performance is really in the top end and not neccesarily low end power?
Mr MTX is offline   Reply With Quote
Old 03-03-2002, 09:34 AM   #358
Motorman's Avatar
Old 03-03-2002, 02:03 PM   #359
stormperson's Avatar
Send a message via AIM to stormperson
i was wondering what fuel you would recommend for a OS TR, and which after run oil? i ran a cvr last summer with BT fuel, however i do think it hindered my lap times, and it had alot of lube in it, so ididnt run after run oil in it.
also, as far as modding a TR, how, much do you think it will help the engine, and what are the down sides so far?
thanks!
stormperson is offline   Reply With Quote
Old 03-04-2002, 12:44 AM   #360
icon's Avatar
Send a message via AIM to icon
From the HPI Engines forum
the RB is a good little engine, shame novarossi are taking away their rights to use the motor soon...so get buying people!
Say it aint so, just say it aint so
icon is offline   Reply With Quote
Cam modified motors (3) crazymechmow R/C Items: For Sale/Trade 12 01-15-2006 02:50 PM
FS: Modified motors (7T, 9T) WeatherB R/C Items: For Sale/Trade 10 09-21-2005 06:56 AM
FS: 3 Richey / Collari modified motors ChrisF R/C Items: For Sale/Trade 3 12-13-2003 06:03 PM
FS: Richey Modified motors ChrisF R/C Items: For Sale/Trade 0 08-28-2003 10:22 AM
dennis richey motors for sale dg8one R/C Items: For Sale/Trade 13 12-10-2002 06:21 PM
