Richey Modified Motors
#166
motor man the spark plug is grey
running 25% blended fuel
standard pipe
have a kyosho tuned muffler but car seemed slower if its on...
year 1995 model but bought much later brand new ... and broken in after breaking in it was seldom played but recently been playing 2-3 tanks everyday for 5 days already LOL
outside temp is around 32 degrees celcius
carb setting
- high needle 2 1/4 turns opened from fully closed
- low needle 2 turns from fully closed used to be 4 but by closing it to 2 we felt that it has better top end
find the engine REVing too much ( noisy ) and lots of smoke ...
fuel last a very short time pickup and topspeed not satisfactory ...
running 2 speed but changed to single speed cause the car wont handle on second gear
even my electrict car seemed WAY faster lol than my friends super 10 so i m helping him out and i need help from the internet
standard pipe
carb setting
#167
Motorman
Dennis, check your PM. Thanks
-Brock
-Brock
#168
Dennis do you have a C4 on-road that's ready and unspoken for???
#169
Originally posted by Motorman
Ok you say the coil was shiny but I am assuming that it quit lighting because the coil was broken. Is this correct? or did it still light but the engine would not run, or ran bad with it in. was the element pushed in or pulled out of the hole in any way.
a few more questions have you used any silicone to seal the engine or used any silicone spray around or to wash out the engine?
Yes the coil was broken ,the element is pushed in and no silicone in any way
#170
Originally posted by jd300zxtt
Tee: or should I say Terry, The engines that I am currently running
are based on my Mentor's (Motorman) philosophy of 2 stroke
engine design...that is I am currently building and running my
own engines of my own modifications...but, that everything I have
learned and incorporated into my engines is DIRECTLY influenced
by my correspondence with Dennis Richey, yet is of my own
design... BTW, the DUDE knows .12 engines!
Regards,
John Allen Dansby
aka jd300zxtt
I wonder if that engine was put in "That Damn yellow car"
would have gotten me second place But you do know you can drive that thing pretty darn good.
Can I pick your brain some more the next time I see you at the track
Regards,
John Allen Dansby
aka jd300zxtt
#171
Heyalignmentguy: Good to see you on the RCTECH site....yes,
I still apologize to you for losing my temper on the driver's stand,
and no, I don't think putting my engine in your car would help at
this time. The 2nd most important thing in rc racing after driver's
skill is the setup of the car...the Kyosho V1-R that you were
racing was similar to Eric Vasutin's in that you were running
gear diffs if I remember correctly and Kawahara 40 fronts and
35 rears...the most important tuning factor I have found in the
V1-R is the front diff. The guys from Castle Hobbies (Eric V.,
Jimmy Duprez) are national caliber racers and both race the
Kyosho V1-R...until they stiffened up the front diff, the car was
very hard to drive at competitive speed. I would suggest that
you touch base with them at Castle Hobbies. If you cannot
get ahold of either, talk to Jaime Manzinilla who works there
M-F 10-5 and runs their setups.....hope to see you at Delta RC
Jan 27th...
Jan 27th...
#173
DENNIS - Can you recommend some websited I can learn the basics and theories of how an RC engine works and how to become an engine tuner like you! I am very interested in learning.
#174
Jan 27th...
Jan 27th...
#175
Were can I buy a Richie Mod. .12? Also what engines do they mod???
#176
#177
#178
What did HAG do?
#179
I sort of beat him into a turn and we touched and sent his car onto its side he wasnt a little bit happy with me or atleast my car found out he was turning faster laps then everyone there after that didnt realise he need'd a kick in the pants to make him drive with a little more athority
#180
Oh so you basically hacked him like you do to me. j/k
John, John, John, they're only TOY CARS. LOL
