Richey Modified Motors
#136
At a big roar event do they weigh the car without tires?
#138
a big ROAR event? I believe it's weight with body & tires, no fuel. The only big ROAR events I've been to, half the guys are running illegal pipes, turbo plugs, you name it. Surprised me; I thought they'd be fairly strict. I'm sure you they'll do a good job at nationals, they need to do it in the www.midwestseries.com
BTW, Dennis; in your gearing example why are you adding the axle ratio to the pinion/spur ratio?
#140
Motorman,
You mentioned reducing the sprung weight - What is this about
#141
Motorman, can you describe why a motor that's run too hot has not bottom? Make it simple if you can.
#143
WOWWW!!
I am utterly speechless...completely overwhelmed by your knowledge. You are like god... (w/ a small g
Seeya.
Seeya.
#144
Originally posted by Jonathan
WOWWW!!
Seeya.
I think I will copy motormans last post and stick it in my pit box for the track
WOWWW!!
Seeya.
#149
ok motorman the TuNeR
u see my friend has a Kyosho Super 10 with standard engine
its has been broken in ...
can you plz tell us how to addjust the timing of the engine?
the low and high setting how many turns etc etc ...
whast a good starting point for top punch and high end speed???
its a OS max engine
Thank u
its a OS max engine
Thank u
