Old 01-17-2003, 06:31 AM   #1
Default engine just dies need help from the pros
i really need some help with this one i,m running out of opti
every time i start my engine it has no fuel pressure it runs untill the pressure in the tank is gone ive pressure tested everything the hose the tank replaced the glow plug even put a new pipe on to no avial all the needles are set to factory standard and the engine has just been run in the engine is a force 12 it was running fine b4 this happened no probs at all
RaTTuS is offline   Reply With Quote
Old 01-17-2003, 08:54 AM   #2
Corse-R's Avatar
Many things can cause a flameout.
Let's make a checklist of things you need to check and give us more information.
  • Check for leaks on your fuel tank, revise the O-ring that goes on the lid of your fuel tank, sometimes it breaks and leaks pressure.
  • Check with another fuel. Probably one of the principal causes of flameouts are a faulty fuel.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-17-2003, 09:04 AM   #3
ill give them a go well what i did find is that the fuel tank lid when you open it it doesnt pop it bascilly just opens but the o rings not broken
so i might change o rings but i,m taking it in to my lhs on monday if i cant get it running i might buy some new fuel as well then and give that a go coz who knows how long theyve had the fuel for
Old 01-17-2003, 12:12 PM   #4
popsracer's Avatar
Default Ofna force .12
RaTTuS;
I've owned one of these engines with the Red Head. I got less than 1 gallon of fuel through it before it would refuse to keep running. I disassembled and inspected, decided that maybe the front bearing was leaking, so I replaced it with a new one. NO difference. After many hours of troubleshooting this engine I finally gave up on it. Never had this problem with any "New" engine before and atribute the problem to very poor quality of workmanship by the manufacturer. Even when I was a "NewBee" I could get over 3 gallons of fuel through my HPI .15FE engines before they were toast. I have one now (.15FE) that is 1-1/2 years old and still running strong.
I recommend taking it to the hobby shop and seeing if they can do something for you.
popsracer is offline   Reply With Quote
Old 01-17-2003, 04:14 PM   #5
Regional Moderator
Darkseid's Avatar
I had an OFNA .15 engine in my Pirate 10 buggy and it held up well even through my.....ummmmm.....less than stellar rookie engine tuning. That was back in '98, I still have that engine in my Pirate 10 and it still runs solidly. Only problem with it is that the front bearing leaks! (it leaves a ring around the inside of the body after every run) But even with that, it has been very solid and was a great first engine.
So OFNA at least has one good engine.
TLR 22...Tamiya F104...
Old 01-17-2003, 05:16 PM   #6
"I've owned one of these engines with the Red Head. I got less than 1 gallon of fuel through it before it would refuse to keep running"
i ve only had a litre through it
i,m going to take it back in. The car is only 3 weeks old so it is still under waranty they test there engines to make sure its not the consumers fault from running the motor to lean but i know damn well it was running as rich as bill gates but anyways thanks for the help and ill reply back when its all sorted and they find what the problem is
Old 01-19-2003, 10:34 PM   #7
well i went to my lhs and they only sell them not fix them but we rang the ppl who distibute them in australia and had a chat to him his verdict was the carby was blocked so i went home flushed the carby changed the fuel lines then played with the neddle setting and evuntully "after a little bit of frustration " vrooom!! the little baby roared back to life and i,m back on the road again thanks to the guys who took the time to offer there help its greatly appretiated
Engine dies jgtruggy Nitro Off-Road 13 12-08-2007 05:27 PM
Engine noise when it dies... pirate252 Monster Trucks 2 12-31-2005 03:05 AM
Engine dies after full load... megasig Rookie Zone 10 05-06-2005 06:08 AM
engine dies tjrcs Nitro On-Road 1 05-17-2003 12:23 AM
engine dies Smoke Rookie Zone 2 04-14-2003 07:51 AM
