Old 06-19-2006, 06:12 PM   #1
Default Just finished building her and setting her up! Mk.2 Pro!
This is my first Nitro 1/10th car in the last 4 or 5 years. Before this I was running a Factory Team NTC3.
I always liked Tamiya and feel that Mk.2 Pro is a very competetive car none the less. I just started to tweak the throttle and engine, so I dont have any idea of power, or speed, but by the way it takes off with a blip[ of the throttle already tells me this car will be sweet once shes setup.
Hope you like my pics. Please feel free to post pointers or whatever you feel may be helpful towards getting the car in top trim.
Cheers,
Sal
Just finished building her and setting her up! Mk.2 Pro!-behind.jpg   Just finished building her and setting her up! Mk.2 Pro!-near-front-shot-side.jpg   Just finished building her and setting her up! Mk.2 Pro!-near-rear.jpg   Just finished building her and setting her up! Mk.2 Pro!-shlammed.jpg   Just finished building her and setting her up! Mk.2 Pro!-back-dragster-look.jpg
Scoobs is offline   Reply With Quote
Old 06-19-2006, 06:13 PM   #2
A few more....
Cheers,
Just finished building her and setting her up! Mk.2 Pro!-dscf1497.jpg   Just finished building her and setting her up! Mk.2 Pro!-dscf1498.jpg   Just finished building her and setting her up! Mk.2 Pro!-dscf1499.jpg   Just finished building her and setting her up! Mk.2 Pro!-dscf1500.jpg   Just finished building her and setting her up! Mk.2 Pro!-dscf1501.jpg
Old 06-20-2006, 01:30 PM   #3
Thumbs up
looks real good
broken4-tec is offline   Reply With Quote
Old 06-20-2006, 06:22 PM   #4
Originally Posted by broken4-tec
looks real good
Thanks man. I worked hard to get it done right. I cant wait to take it out to a practice and finish the setup.
Cheers,
Sal
Old 06-22-2006, 10:33 PM   #5
Carbonfi_dragon's Avatar
Default Nice car!
Love the car! Do you not find the yellow springs a little on the soft side though?? It is great to see that there are other people with this car. They are quite rare, even here in Japan. Also tuning this car is quite expensive. I have spent the same amount of money tuning my Mk.2 PRO as it would cost to buy an MRX4 (62,000 JPY) and a MTX4 (38,000 JPY)...
My TG10-Mk.2 PRO is fully tuned, 100,000JPY+ spent on the car, have upgraded the car with every product I can find other than:
Racy carbon upper plate, Racy aluminium racing chassis and Racy carbon front plate, - Hopefully will arrive this Thursday! - Also upgrades not included in the pics - TRF Special blue damper set
Pics (although not that up to date my camera is bust) can be found here: http://www.personal.leeds.ac.uk/~eas4cpm/
(Only the top pics are of the car!)
Here are my car specs:
Main equipment
-OS Factory Tuned TZ.12(P) 5-port engine (2.1cc output, 13.8mm bore x 14.0mm stroke, 5,000-40,000 RPM, 1.62PS @ 34,400RPM) weight 224.5g, black heatsink replaced with silver item.
-Running on Tamiya TG-30 (30% nit. fuel)
-Using OS P7 "medium" turbo glow plug.
-Upgraded large air intake (EAST E5054 for .12-.21 engine)
-X2 Futaba 53050 servos, 48.8g each (10.16sec/60 [email protected], 6.5kg/[email protected] torque).
Upgrades included in Pro kit
-Tamiya full ball bearing set OP.8, OP.30, OP.65, OP.66, OP.126
-Tamiya front one way differential set OP.885
-Tamiya 2mm carbon upper deck 2024003+9444509
-Tamiya 2-speed gearbox
-Tamiya sponge tyres: F(No.37 - (OP.742): 26mm wide, 65.5mm diameter sponge. R: (No.35 - (OP.745): 30mm wide, 65.5mm diameter sponge
-Tamiya TM-9 race-tuned muffler
Additional upgrades
-Tamiya battery and receiver rubber bag set SP.194
-Tamiya 32mm fuel filter GE.5
-Tamiya anodised engine mount OP.797
-Tamiya full titanium screw set, 97pcs total - 1/2 weight of original screws, overall weight saving of 33g OP.740
-Tamiya blue anodised aluminium (1mm lower) damper down retainer set (4 pcs) OP.876
-Tamiya hard front spring set OP.751
-Tamiya hard rear spring set OP.756
-Tamiya racing clutch spring (medium) OP.737
-Tamiya hard rear stabilizer rod OP.739
-Tamiya adjustable front stabilizer OP.796
-Tamiya clamp type aluminium wheel hubs (6mm thick type) OP.569
-Tamiya universal shaft set pair (x2) OP.795
-Racy carbon front body mount brace RTG.253
-Racy carbon rear body mount brace RTG.254
-Racy carbon front damper stay RTG.269
-Racy carbon rear damper stay RTG.270
-Racy drilled stainless uprated brake disc RTG.255
-Square lightweight front centre universal shaft STX.22F (replacing Tamiya F+R strengthened prop. shaft OP.888)
-Square lightweight rear centre universal shaft STX.22R (replacing Tamiya F+R strengthened prop. shaft OP.888)
-Square titanium suspension balls (8 pcs) - standard parts 3.39g each, Square parts 1.88g each, 12g overall weight saving STX.80
-Square aluminium rear deck holder STX.37
-Square aluminium anodised output shafts (front and rear) STX.6
Carbonfi_dragon is offline   Reply With Quote
Old 06-23-2006, 05:12 AM   #6
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
  • trim the body post's......(so you don't look like a noobinski.....)
  • whetever that entanglement is on the left side of the car is,make sure there is no on/off switch there....nothing like a T-BONE collision to shut the car off
and get the fuel line away from the head,.....
nice car....have fun racing...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-23-2006, 06:59 AM   #7
Thanks for the pointers man. The body you see was the first I have done in years...ill be sure to trim it up, so that I dont look like a NOOB...
I dont run on off switches in my cars...I plug the source dirctly into the reciever.
Cheers and thanks,
Sal
Old 06-23-2006, 07:01 AM   #8
Main equipment
Additional upgrades
WOW...sounds like you are sporting a pretty slick Mk.2 The Yellow springs are cool...little soft, but not that bad for the area I practice on....ill probally chage it up to whites once I hit the track.
last night I put a fresh new set of universals on the car
Cheers,
Sal
Old 06-24-2006, 04:08 AM   #9
Hey Sal!
Yup, you will like the white spings I am sure...Make sure to change the Stabilizer bar as well!!! For me I always use the blue (hard) one, regardless of what springs I am using. I noticed a vast improvement with the harder springs, I mostly use white rear, Ex. hard (dark-grey) front, or F+R dark grey springs.
I will finally get my racy upper deck and chassis plate this week, should be much better as the batteries are more accessible with it.
The universals are a great upgrade!!!
BTW Out of interest, I bought the PRO kit, and despite having used the strengthened prop. shafts (heavy!!) I also bought the aluminium universal ones from Square...I found that not only were they more smooth (being universal) and lighter, but even running the OS Speed factory tuned TZ.12 engine I have yet to break them, so I think it is a very worthwhile upgrade, well worth the money!!
Enjoy the car and happy racing!!!
Old 06-25-2006, 05:24 PM   #10
here's a good post for you.
http://www.tamiyaxtreme.com/forum/vi...asc&highlight=
romuald31 is offline   Reply With Quote
Old 06-25-2006, 05:27 PM   #11
WOW...thats alot for the reply guys. I appreciate it. I love my Mk.2 Pro. SOLID car and very competetive. Im having some linkage and 2 speed issues (doesnt want to engage), but once those are sorted out im sure ill be very happy.
Cheers and thanks again,
Sal
Old 06-26-2006, 02:53 AM   #12
Bundy_Bear's Avatar
Scoobs:
Nice Acer Ferrari F20 20" WXGA Monitor.... gotta love CrystalBryte
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 06-26-2006, 08:54 AM   #13
Originally Posted by Bundy_Bear
Scoobs:
BB
Heh...Thanks bud. I love the F20
Sal
Old 06-27-2006, 11:11 AM   #14
Hi Rom!
Yeah check out the first page of that link...3 of us use tuned Mk.2s...
Have fun with the car...
Oh, and for upgrades...check this out, new in Japan...
http://www.eaglemodel.com/
(You must enter the Japanese language site, the English does not have the product ) Then go to modified parts (side menu), and select Tamiya TG10-Mk.2 and you will find their newest upgrade part released over here in Japan, at a great price of 7,500 JPY...I am enjoying mine very much!!
You can go straight to:
http://www.eaglemodel.com/jp-net/cat...0category.html
And select the TG10-Mk.2 for the pic...really nice parts!!
Bests
Old 06-27-2006, 11:17 AM   #15
Scoobs,
What problems are you having with the linkeage?
The 2-speed should be find, just make sure the screws are turned out according to when you want the shift change....and make sure the internals are ok...
Finally Finished! SPO Electric On-Road 6 08-30-2006 03:20 PM
Well, it looks like my new O.S. is finished... RiceEatin1995GT Nitro On-Road 16 11-23-2005 10:35 PM
Brushless HPI RS4 MT (Finished for now) Wicked Electric Off-Road 3 07-14-2005 01:39 AM
Just Finished X-Ray T1 Evo 2 warlord385 Electric On-Road 1 01-28-2003 05:28 AM
Finished Gt4 Maxspeed1 R/C Items: For Sale/Trade 17 10-26-2001 07:45 PM
