Old 03-31-2003, 06:21 PM   #121
Hi
I got my LD3 last sat have been busy rebuilding it the build is very good and has some tuning parts in the kit like the arm holder to change the anti squat deg. the kit I got did not have engine bet it is 80% bulid. will have more info later.
Kylelim is offline   Reply With Quote
Old 03-31-2003, 07:12 PM   #122
spenzalii's Avatar
Send a message via AIM to spenzalii
A rebuild already? What happened? And where did you go to get a prebuilt kit? I thoughtthe only ones they had out were RTR
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 03-31-2003, 10:54 PM   #123
Hi
I rebuild the kit is because I want to put silicone grease in the diff I did not rebuild the whole car just some adjustment here and there. I got my kit from my LHS they only have those 80% build w/o engine.
Old 04-01-2003, 07:21 AM   #124
spenzalii's Avatar
Alright. What weight oil do you plan on runnig? And which engine? Any input will give me a jump on what I should be looking for when mine shows up. If your LHS actually had one in stock, I may have to make that trek out to the best stocked (albeit farthest) shop in the DC area is and find my parts.
Old 04-01-2003, 07:05 PM   #125
Hi I am putting kyosho 6000 silicon in front and 4000 rear, i took out one of the shimm to make the diff smoother and i am planing to buy 2 more diff gears to make it to a 6 gear diff as in the pro kit.
Old 04-02-2003, 03:33 AM   #126
where can i find an LD3 Pro of RTR?and are the parts from the LD3 the same as the NTC3?
shortyboy is offline   Reply With Quote
Old 04-02-2003, 07:13 AM   #127
spenzalii's Avatar
Nitrohouse has the RTRs (both 1 and 2 speed) in stock. As far as parts compatability, I'm not sure just yet. I'll have to wait until I get it. I believe the suspension (especially the rear) was lifted from the OB4
Old 04-02-2003, 04:40 PM   #128
Send a message via AIM to Bryan N.
The pro is not out yet, and as far as I know almost nothing is interchangable with the ntc3 except for maybe the spur gears, shaft, springs, and tires .
Bryan N. is offline   Reply With Quote
Old 04-04-2003, 08:03 PM   #129
i was wondering if the ntc3 2 speed could fit in the LD3?and probably the threaded shocks and centax?looks like a perfect fit,if so i might consider purchasing 1.
Old 04-04-2003, 10:14 PM   #130
spenzalii's Avatar
shortboy,
The shocks I understand. Not sure if the RTR has adjustable shocks on there now, but you could swap just about any shock with a bit of fitting. Why would you want the 2 speed from the TC3? The LD3 comes with one. Now for the Centax, I'm not even sure. With the price involved to be wrong, I'd wait until Ofna puts one out. Patience may pay off in this instance
Old 04-05-2003, 08:41 AM   #131
Registered User
OB42TC3's Avatar
Any of the metric centax clutches will work and Ofna also makes their own. You just need to make sure the clutch bell gears are the same range; but I think they are in general.
OB42TC3 is offline   Reply With Quote
Old 04-05-2003, 11:14 PM   #132
i wanna buy the ld3 rtr but the only one available on ebay is the single speed.it only costs 200,what a steal and i see a ntc3 2speed for 40.pretty cheap for an rtr with 2speed.im also considering running a centax,it should fit if the ntc3 2speed fits.the ld3 looks awsome!especially the chassis.anyone know where i could find a ld3 rtr w/2speed for cheap....like around 250-280?
Old 04-06-2003, 08:21 AM   #133
Registered User
OB42TC3's Avatar
www.nitrohouse.com they are the US distibutor of OFNA. I would buy the 2-speed kit because the aftermarket ofna 2-speed is ~$80. No way the NTC3 2speed will work because of the standard bearings, and the LD will use metric.
Old 04-06-2003, 11:29 PM   #134
Hi, Just want to let you guys know that RDLogics 1 piece NTC3 will be fully compatible with LD3 Pro. Thanks
rdlken is offline   Reply With Quote
Old 04-06-2003, 11:41 PM   #135
where did you get your LD3 Pro from?
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
