Old 06-17-2006, 08:21 PM   #1
rcrevolution's Avatar
Send a message via AIM to rcrevolution
Default IS this Possible?
This might be a dumb idea, and I'm probaly better off leaving the pullstart on but I have an idea and I was wonderinf if this will work.
I have an OS .12CV-RX, I wanted to remove the Pullstart, the starting shaft, and JB weld the hole on the backplate so I can run it with our a pullstart.
Will JB weld widthstand the pressure and temp? or is this a bad idea, I never used JB wed so I don't know.
the site says it can take temps up to 600F, but I don't know if the pressure is too great.
rcrevolution is offline   Reply With Quote
Old 06-17-2006, 08:24 PM   #2
nevermind people, JB Weld costs more then the non pullstart backplate itsself, shoulda checked its price before posting this, I'll just get the non pullstart backplate.
Umm what notch do I have to cut off on the crankshaft for it to fit?
Old 06-17-2006, 10:45 PM   #3
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
You're cutting off the nub that comes into contact with the oneway bearing in there. Just remember once you go non p/s you can't go back unless you purchase a new crankshaft. Cut the nub, make sure engine is clean of shavings and all debris, reinstall, use non p/s backplate. Use just a little threadlock on the screws...you don't JB weld the backplate.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-17-2006, 11:19 PM   #4
seriously man, I talk to you on AIM, stop following me and answering the questions I ask you on forums, I already know your answer
Old 06-18-2006, 01:35 AM   #5
HarKonnenD's Avatar
1)no one follows you.
2) You never asked me on AIM for help or the same question.
3) If you know the answer don't post.
Old 06-18-2006, 02:54 PM   #6
1) you come here to asnwer the question i asked
2) yes i did ask the same question in AIM, you just don't remember or didnt listen
3) I postsed this way before I even asked you about it
Old 06-18-2006, 05:00 PM   #7
HarKonnenD's Avatar
All lies. Someone else please answer his simple question which he has asked other people already...
