Old 06-14-2006, 05:43 AM   #1
Default Brakes?
Is it typically better or worse to dial in some brakes on a nitro touring car, i.e., with no throttle, the car will gradually come to a stop vs coasting?
atr4tigers is offline   Reply With Quote
Old 06-14-2006, 05:54 AM   #2
fritzD's Avatar
Send a message via Yahoo to fritzD
It depends entirely on the size of your track. Our track here is small and very technical. If I use Rubber tires and Front diff, I use brakes on the straight and brakes on the technical part if im pushin my car. If i use foam tires and front one way, i hardly brake.
fritzD is offline   Reply With Quote
Old 06-14-2006, 05:56 AM   #3
itchy b's Avatar
i've found that it's better and easier to drive my car with the brakes set to only engage when i apply the brakes
when the brakes are rubbing when you back off the throttle it makes the car hard to maintain corner speed in some cases that you need to
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
no brakes greenthumb1977 Nitro Off-Road 1 06-21-2008 05:31 AM
Top Driving Styles: Using Brakes and Drag Brakes SlamMan Electric On-Road 32 04-30-2007 11:11 PM
QC2 - No Brakes? Jam-ehz Electric On-Road 2 01-23-2006 02:12 PM
Need help with brakes jigga21 Monster Trucks 1 07-25-2005 03:56 AM
Brakes ? imjonah Electric On-Road 10 10-30-2004 08:54 AM
