Old 06-01-2006, 11:38 PM   #1
Default evolva 2005 team edition
i just got one and how is everyone hooking the on and off switches up? theres nothing in the instructions about it?
thanks
ZWILLDOG is offline   Reply With Quote
Old 06-02-2006, 12:28 AM   #2
Arno's Avatar
thanks
Me personally I don't use a switch I just plug the battery right into the receiver when I need it on and unplug it when I want to turn it off. And alot of people do the same because the switches tend to go bad after a while, or if you get into a bad crash and the switch gets hit they could stop working and you will not have any signal from your radio to your receiver and that can cause your car to run away. Hope this helps.
Arno is offline   Reply With Quote
Old 06-02-2006, 07:28 AM   #3
Grinder's Avatar
thanks
I made a place for a switch in the upper deck just in front of the antenna tube. make the proper holes in the graphite, then mount it up. I have mine so that it sits left to right on the car. Super clean look. I will post a picture tonight.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 06-02-2006, 05:59 PM   #4
bsmooth's Avatar
Trader Rating: 17 (100%+)
KO Propo makes an electrical switch that is good. Stay away from the mechanical type switches for the above reasons.
-Steve
bsmooth is offline   Reply With Quote
Old 06-02-2006, 09:47 PM   #5
Team Kamikaze's Avatar
What kind of receiver pack does the EVOLVA take ? what size battery and what configuration?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-02-2006, 10:27 PM   #6
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
It uses 5 AA batteries side by side.
Racing4Evo is offline   Reply With Quote
Old 06-02-2006, 11:23 PM   #7
Don't do the switch. It is much cleaner for setup and wire routing
silverM3 is offline   Reply With Quote
Old 06-03-2006, 01:58 AM   #8
Does skyline makes these batteries? and is it available?
Old 06-03-2006, 05:27 AM   #9
Grinder's Avatar
thanks
Here is a picture of my switch. I don't use the KO electrical switch because it drains the battery even in the off position. This switch setup works great for me.
Old 06-03-2006, 12:05 PM   #10
Corse-R's Avatar
My method is quite similar to the SuperSerpent one, but with a slight modification.
A Multiplex (MPX) battery connector goes from the receiver to a place in your chassis and the wires that came from battery use the same connector. This is quite different to the servo ones, so no place to fail to connect them, when connected grip themselves very tough so no worry to self disconnect when running.
Here is a very common battery connection method. Look at this photo just for more details.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-03-2006, 03:17 PM   #11
SRAD's Avatar
Default re
Off the subject just a little.....how many versions of the 2005 Evolva are there? Team Edition and WC Edition...are they the same? Plus the regular vcersion. Are there more?
SRAD is offline   Reply With Quote
Old 06-03-2006, 06:32 PM   #12
Maddin21's Avatar
There are only two versions of the Evolva 2005...
Evolva 2005
Evolva 2005 (WC) Team Edition
---Maddin---
Maddin21 is offline   Reply With Quote
Old 06-06-2006, 10:09 AM   #13
quick question for Kyosho guys, which steering ackerman gives you the most aggressive steering?
p.s. dont use the switch on my car
Alex
brooklynrc is offline   Reply With Quote
Old 06-06-2006, 12:10 PM   #14
captian's Avatar
the lower the number to more steering
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 06-06-2006, 01:07 PM   #15
Thanks Jimmy, see you at the track
Alex
Kyosho Evolva 2005 jrabbito Nitro On-Road 413 05-30-2009 09:57 AM
Kyosho Evolva 2005 kit $250.00 skriete R/C Items: For Sale/Trade 3 07-25-2006 01:18 PM
2005 Kyosho Evolva New in Box ATOMIC R/C Items: For Sale/Trade 0 05-01-2006 09:07 PM
New in Box 2005 Kyosho Evolva $550.00 ATOMIC R/C Items: For Sale/Trade 5 04-30-2006 09:57 PM
