Old 05-21-2008, 04:02 PM   #1471
quietstorm76's Avatar
Originally Posted by MugenDrew View Post
What engine? Is the bowl closed now?
The bowl is still open and we race 1st and 3rd sunday. Visit Go-Rc.org
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-21-2008, 10:19 PM   #1472
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by quietstorm76 View Post
Bobby where are you going to run it?
bowl hopefully when i get time off from work and i need you help to set it up ...right now im waiting on my engine and pipe to come in the mail so can you help me?
bobbyblaze is offline   Reply With Quote
Old 05-22-2008, 06:26 AM   #1473
You know I will help what engine are you getting?
Primary Weapon: ?
Secondary Weapon: ?
Old 05-22-2008, 08:44 AM   #1474
bobbyblaze's Avatar
ninja and pipe i got a medium manifold is that ok or should i order a short one?
Old 05-22-2008, 11:13 AM   #1475
The medium is fine.
Primary Weapon: ?
Secondary Weapon: ?
Old 05-22-2008, 11:15 AM   #1476
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Yes that engine will work well with either INS box.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 05-23-2008, 04:14 PM   #1477
reemo_2001's Avatar
Default NOOOOOB???????
Hello Mugen guru's, I'm new to the 1/8 onroad and I have a question. Which screws in the mrx4's 2speed do you adjust to change the shift point? Is it the center set screws which move the metal ball, or the outer 2 bolts with the springs? Also do you have to adjust both sides each time you adjust the shift point? I couldn't seem to find the answer to this question.
Thanks in advance
reemo_2001 is offline   Reply With Quote
Old 05-23-2008, 04:25 PM   #1478
MugenDrew's Avatar
The two screws with the springs are the ones that adjust the shift point. Yes you should adjust both equally. The two that sit above the balls are used to adjust how smooth the transition is from first to second. I set those screws so that the shoes are as close as possible to the two speed housing with out dragging. This provides a very smooth predictable shift that will not shock the drive belts and pulleys or the contact patch of the tires. Down side this it does cause some slippage. So when it's time for new two speed shoes it's time for a new two speed housing.
Old 05-23-2008, 04:37 PM   #1479
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
Mugen message board is now on and live as of 5/23 2008
www.mugenracing.com click on message board create an account and start posting just that easy.
Hopefully this will help people with questions in-regards to setup tips and other frequently asked questions.
ROBBIE C is offline   Reply With Quote
Old 05-23-2008, 09:41 PM   #1480
reemo_2001's Avatar
Default Thanks
Thanks man for the help, this is the only thing that I havn't had to mess with since I bought the car. It has always work/shifted perfect for my taste until the shaft started to get stuck between the shoes, causing the car not to shift and also making the second gear wabble.
Thanks,
Old 06-08-2008, 08:32 PM   #1481
bobbyblaze's Avatar
what a good set up on the toe & camber for the MRX4R ...... is the stock setting is a good start or what you guys perfer
thanks
bobby
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
Old 06-09-2008, 04:41 AM   #1482
thanks
bobby
Run the box setup. That's what I'm running at the Bowl. 35's fr/Rr. What body are you going to run?
Primary Weapon: ?
Secondary Weapon: ?
Old 06-09-2008, 08:25 AM   #1483
bobbyblaze's Avatar
the kit came with a shadow body but i have a question what do this part do or where it go on the body?
Old 06-09-2008, 08:37 AM   #1484
lil-bump's Avatar
Trader Rating: 83 (100%+)
Those are body stiffiners. You cut them in strips. they look like plastic L-brackets. You mount them from the side of the body to the top. It gives the body more rigidity when traveling at speeds.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-09-2008, 08:46 AM   #1485
bobbyblaze's Avatar
thanks ...this my 1st 1/8th onroad car
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
