Old 01-08-2008, 07:05 PM   #1396
Trader Rating: 15 (100%+)
Originally Posted by JASON MAC View Post
Clutch tool is not included. You can use the hard spring in the kit, but the MSR spring works much better. Depends on you driving style.
The stock spring will only last two race days at the max. After that you will find that your car will start to bog coming out of the turns and seem to not really clean itself out until the straight.
If you want the correct spring from the start use the MSR spring. This spring will only last at most about five races. They get heat cycled and loose their spring pressure.
THE DOCTOR is offline   Reply With Quote
Old 01-08-2008, 09:49 PM   #1397
jeff1's Avatar
Questions?? pulleys doubt
thanks for reply regarding the body
Now I need advice on the pulleys.. I need to replace the brake and rear big pulley rigid
There is two codes H0280 and H0251
which one should I get?
jeff1 is offline   Reply With Quote
Old 01-08-2008, 11:28 PM   #1398
The pulley set is H0280. It comes with all the pulleys for the car.
JASON MAC is offline   Reply With Quote
Old 01-09-2008, 09:24 PM   #1399
jeff1's Avatar
Thumbs up
Thanks for let me know
Old 01-10-2008, 09:04 AM   #1400
CanyonCarverR1's Avatar
Default Protoform Frizbee
On the Protoform Frizbee body, are you suppose to cut out the front face of the engine fairing? If not, it seems there would be a high pressure area there, decreasing airflow through the cylinder head, yes/no?
CanyonCarverR1 is offline   Reply With Quote
Old 01-13-2008, 06:51 AM   #1401
bozla's Avatar
What thickness damper oils do u run?
bozla is offline   Reply With Quote
Old 01-13-2008, 10:56 AM   #1402
600wt most of the time.
Old 01-13-2008, 01:24 PM   #1403
jeff1's Avatar
Questions??
Does anybody use or used Kawahara Audi body #KT-001?
there is also the Blitz 06 which seems to be good
Old 01-19-2008, 10:02 AM   #1404
Default long and short arms
Hi....u got long or short body arms for fixing the rear upright to. Hence wot do the effects of that have with the different arms and different positions on the body mount on handling of the car ?
xtreme888 is offline   Reply With Quote
Old 01-19-2008, 04:50 PM   #1405
sorry....
another question what the effect of mounting the front turnbuckles under the uprights instead of above ?
Old 01-30-2008, 08:29 PM   #1406
jeff1's Avatar
Anybody is using the Central Lola CR-404 V2? How good
Old 02-08-2008, 01:51 AM   #1407
PROVK's Avatar
Trader Rating: 14 (100%+)
If I want to gain some bottom end and change to a 16T pinion, do I have to drop a tooth on the second gear pinion to keep a proper gear mesh?
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 02-09-2008, 05:06 PM   #1408
Any news on how swauger and his MRX4X & JP combo .. Is the Swaugzilla back in form yet?
seikob is offline   Reply With Quote
Old 02-09-2008, 09:57 PM   #1409
jeff1's Avatar
Anyone knows a place that sells MRX4X conversion kit?
Old 02-12-2008, 06:06 PM   #1410
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i have some arms forsale if any one can use
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
