Old 06-27-2007, 05:01 AM   #1231
cdelong's Avatar
constantly stripping gears with everything (gear mesh, shaft side play, etc...) set-up properly sounds like a one way problem. Clean the one way and re-lube it.
cdelong is offline   Reply With Quote
Old 06-27-2007, 05:51 AM   #1232
feroz's Avatar
Default 7.4v lipo
do any of you run lipo batteries in ure 1/8 scales.do you guys recomend it or should i just run nimh 5 cell packs?thanx in advance
Rovan baja 29cc, SavageX 4.6 stock, SavageX Z28R spec3, SavageX Alpha.28,
MRX4X Collari 35+21, MRX5 Collari 35+21, serpent 835 rwd RB X15,
Revo 21 TM, TMAXX 3.3 stock, Jato 3.3 stock, schumacher nitro fusion .28, JR Z1 DSM.........
feroz is offline   Reply With Quote
Old 06-27-2007, 07:40 AM   #1233
quietstorm76's Avatar
Originally Posted by Osiris 75 View Post
I started stripping the first gear recently. I practiced an entire day on the same gears, then all of the sudden I started stripping them. I thought it was my pinion gears, but my friend borrowed my engine, pinions included and he did not strip. I did notice my rear shaft was moving, so I tightened it down to where it would not move at all, but I still stripped.
Check your 2 speed shaft bearings. If they go you will strip gears because your mesh will vary.
quietstorm76 is offline   Reply With Quote
Old 06-27-2007, 08:21 AM   #1234
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Thanks guys, I'll give it a try!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-27-2007, 03:42 PM   #1235
Trader Rating: 93 (100%+)
Default Lipo
I run lipos in my xr8 but in the mrx4r i don't because the battery that is designed for it has plenty of runtime with good servos. I would say a lipo would be better if they don't scale your car because it will be lighter and is under weight with a ni-mh battery. In any kind of racecar lighter is faster!
latemodel13 is offline   Reply With Quote
Old 06-27-2007, 08:05 PM   #1236
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Side to side play should is adjusted by the pulley that runs the side belt. Lipo,s are light and so are Mugens. I run a ni-mih and a brass tray to keep the wieght low.
MugenDrew is offline   Reply With Quote
Old 07-06-2007, 07:48 AM   #1237
feroz's Avatar
Default engine?
any1 try the MRT ninja as well as the eagle R9 from JP?really interested in either one them...
thanx in advance
Old 07-06-2007, 08:13 AM   #1238
sohlman's Avatar
Trader Rating: 89 (100%+)
thanx in advance
I've been running the MRT...f'ing fast! Makes runtime, stays cool (maybe too cool sometimes) and pulls in every part of the track.
Don't know about the JP. Not sure how much it costs, but if its anything like what their prices used to be, then forget it.
Steve Sohl
sohlman is offline   Reply With Quote
Old 07-08-2007, 09:39 AM   #1239
thanx in advance
You should try JP. JPs engine has lots of power.
Johny is offline   Reply With Quote
Old 07-09-2007, 02:46 AM   #1240
feroz's Avatar
I've been running JP engines for some time.R03 ceramic R01 stock and maybe if all goes well,R9 as well
I just finished running in my XENON speedline from RB(abc version)Apparently,they run like hell.i'll just have to c for myself.i hope it goes as well as my C5,maybe better
Old 07-15-2007, 08:36 PM   #1241
Pooh2's Avatar
Send a message via MSN to Pooh2
Where r all my Mugen guys? The MRX4 R is a great car!!!! There has 2 b something 2 talk about?
Pooh2 is offline   Reply With Quote
Old 07-15-2007, 11:30 PM   #1242
asw7576's Avatar
Hi there, yesterday I won 3rd place in B final 1/8 Indonesian National Series with my MRX4-R.
I remove the front stabiliser and the car turn very easy ( I'm talking about mid cornering and corner exit on full throttle ).
Old 07-16-2007, 03:19 AM   #1243
What body were you running? I've had problems with a mid corner push as well. I was using a Parma and with advise from Pooh I'm trying the Serpent/Central body. Never thought about removing the sway bar.
Old 07-16-2007, 05:08 AM   #1244
asw7576's Avatar
I'm using Serpent body.... don't know the real name.
I heard the new 1/8 protoform and kawahara are the best in business..... I haven't buy it yet.
I would test these for mid cornering push :
(1). Put the caster clips all the way front ( the caster is more lay down )
(2). Lay down front shocks to lowest setting ( more lay down )
(3). Change front spring to grey ( softer than white ).
Old 07-16-2007, 06:11 AM   #1245
sohlman's Avatar
We're racing! And when a car like the MRX4R works this well, every time you go out, then there's nothing to discuss.
Except maybe how well you did. Good job asw7576!
What's good with you, Pooh?
Steve Sohl
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
