Old 06-21-2007, 08:23 AM   #1216
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
Originally Posted by feroz View Post
im sorry if my Q was abit stupid.didnt sound funny though. but thanx anyways.by the way,im from South Africa.so u r better off buying a kit closer to ure home
No worries, Feroz. Just clowning around with you. Mugen is a great brand and I am waiting until the fall to get a 1/8 myself. If there is a new one in the pipeline, I would be interested in hearing about it as well.
va_connoisseur is offline   Reply With Quote
Old 06-21-2007, 08:47 AM   #1217
feroz's Avatar
no hard feelings dude.a friend of mugen is friend of mine stay stress free=ride a 1/8
Rovan baja 29cc, SavageX 4.6 stock, SavageX Z28R spec3, SavageX Alpha.28,
MRX4X Collari 35+21, MRX5 Collari 35+21, serpent 835 rwd RB X15,
Revo 21 TM, TMAXX 3.3 stock, Jato 3.3 stock, schumacher nitro fusion .28, JR Z1 DSM.........
feroz is offline   Reply With Quote
Old 06-22-2007, 09:00 AM   #1218
feroz's Avatar
Default allmod RV01
has anybody used this body?how does it go?
Old 06-22-2007, 11:02 AM   #1219
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by darkangel View Post
A new car won't make you faster.
It makes your pockets lighter though
T-Sal
gashuffer is offline   Reply With Quote
Old 06-22-2007, 02:54 PM   #1220
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Have not tried it, but have heard good feedback about it. I'm sticking with the Parma body this season...I prefer to reduce the variables in a set-ups.
Carl Giordano is offline   Reply With Quote
Old 06-23-2007, 05:25 AM   #1221
feroz - no flame were intended. Just see too many people think that the latest car/hopup/whatever will make them faster automatically.
Who makes that body? Looks a lot like a heavily moded Dome body.
darkangel is offline   Reply With Quote
Old 06-23-2007, 05:46 AM   #1222
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Its made by Mid Mugen Seiki in Germany http://www.mid-mugen.de/
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 06-26-2007, 08:37 AM   #1223
feroz's Avatar
sometimes a hopup just makes the fine tuning a little easier and sometimes makes a small difference in handling.
for example,when converted my 4 into a R,i did it slowly to c the difference.trust me,it did.like changing the front and rear bulkheads,u are able to adjust the tension on the belts.when changing to H0474 chassis plate,the motor ran slightly warmer due to there being no cut-outs under the engine....and so on and so on..
so not because i think it will make me faster,it just improves the car on a whole.that is how i could c the small differences cheers dude,keep on riding
as for the body,will be getting 1 in about 2 weeks time.will keep u updated on how well it goes.
Old 06-26-2007, 08:47 AM   #1224
feroz's Avatar
practise and setup are the only hopes of being able to go faster along with patience and a "stress-free" mind set.concentration is always a factor.
what u put in is what u get outjust my opinion.
I would like to come out to the states and Canada one day just to see how ure tracks look and maybe even race there just once....
oneday
Old 06-26-2007, 08:59 AM   #1225
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Has anyone had any problems with stripping gears??
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-26-2007, 11:45 AM   #1226
Corse-R's Avatar
Never... but... pay attention to the image attached. Comes from the MTX4 manual, but on the MRX you could be suffering the same problem.
Remove the balls marked in red and swap the grub screws for one of 3x8mm. If the 2nd gear clutch support is scored, change it for a brand new one.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-26-2007, 06:05 PM   #1227
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Yes And no . Due to the power your dealing with it is very important to pay attention to mesh between rounds. Be anal about checking it before the main. I ripped all the teeth off of first gear at Kissimme becuase I was busy with another issue and neglected to check my mesh for four rounds of qualifying. As far as the two speed, what Course-R said and you always want to run the shoes as close as possible to the housing. You may not be able to "feel" or see it shift but your greatly reducing the shock of the shift. What gear are you stripping?
MugenDrew is offline   Reply With Quote
Old 06-26-2007, 10:31 PM   #1228
Osiris 75's Avatar
I started stripping the first gear recently. I practiced an entire day on the same gears, then all of the sudden I started stripping them. I thought it was my pinion gears, but my friend borrowed my engine, pinions included and he did not strip. I did notice my rear shaft was moving, so I tightened it down to where it would not move at all, but I still stripped.
Chris Kemper
Old 06-27-2007, 03:25 AM   #1229
feroz's Avatar
i also experienced this a couple of weeks ago.my gearbox shaft had a +- 3mm
play(side2side)to reduce the play,i took a std glowplug washer and used it as a shim behind the pin that holds the shaft in place(behind the 2spd shoes)always make sure your meshing is 100% accurate.they must not be too tight and at the same time not too loose.spin them freely to check.make sure ure engine mount screws thread is not worn(top and bottom)just my opinion.use it,dont use it,i could be wrong..trust me,i stripped 3 sets of spurs in 1 day and finished a 15 minute final with only a first gear
cheers buddy.
Old 06-27-2007, 03:35 AM   #1230
feroz's Avatar
Default eagle
has anybody used the new R9 eagle from JP?if so,how does it go?just curious thanx in advance
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
