Old 05-29-2007, 12:14 PM   #1156
asw7576's Avatar
Originally Posted by Spillertwo
Nitro junkie,
Put the bearing in which slot ? The only hole available is where the screw is to secure the roll bar.
You can not pull the upper belt under the tensioner because it creates way to much tension that way. The belt tensioner hammer is about level with the under part of the belt
As I said , throw a brick to M Mod.
It's BS
Old 05-29-2007, 12:37 PM   #1157
Spillertwo's Avatar
Nitro Junkie is the man
This is how i mounted it now and it seems to work.
Can't run the top belt under the bearings because that way it is way to tight even if you move the bearings all the way up on the hammer opening of the tensioner.
What do you think ?
And just to think I thought I would be rid of the bearings with this solution
But as long as we can figure out how it is supposed to work together I am already much happier now
Spillertwo is offline   Reply With Quote
Old 05-29-2007, 12:42 PM   #1158
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Your almost there now adjust/slide the bearing so its up higher on the slot then try and get the top belt under.
The slots are there so you can fine tune the tension you want if you cant cause the back nut is hiting the back of the tensioner use nylon threaded nut and smaller screw if that hits as well the hammer should still move up and down
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-29-2007, 12:48 PM   #1159
The top belt has to go under other wise the belt is gonna rub on the madifold when you install it try it with a stretched old belt.
The spring on the hammer will most likly loosen up a bit after a few runs and the hammer it self will sit a little higher
Futaba
Mugen
Novarossi
Byron's
Old 05-29-2007, 06:18 PM   #1160
gashuffer's Avatar
Trader Rating: 48 (100%+)
What was wrong with the stock tensioner?
T-Sal
gashuffer is offline   Reply With Quote
Old 05-29-2007, 11:28 PM   #1161
asw7576's Avatar
What do you think ?
Yeah........ you almost there. You need a liltle shock damper to minimise high frequency vibration from the belt. Maybe 30W damping oil will do the job.
Old 05-30-2007, 03:42 AM   #1162
So did you get it???
What do you think ?
Futaba
Mugen
Novarossi
Byron's
Old 05-30-2007, 06:35 AM   #1163
Spillertwo's Avatar
Final result and it seems to work.
It tightens up the belt quite a bit but the car still
feels good when you turn the wheels.
So thanks everybody for the great help
Old 05-30-2007, 09:04 AM   #1164
asw7576's Avatar
Ahhh.... much better.
Now put on your engine and see how close the belt to under side of manifold.
Old 05-30-2007, 02:16 PM   #1165
Spillertwo's Avatar
Is not a problem with the engine manifold. I can still put my little finger between the belt and the manifold. More than enough room.
Old 05-31-2007, 01:40 PM   #1166
%Yanlei%'s Avatar
Is the idea of that upgrade that the spring automatically keeps the belt optimally tight as the belt gradually stretches, so that you do not have to alter the standard tensioner manually ?
I guess its good to be in the RC bling manufacturing business...
%Yanlei% is offline   Reply With Quote
Old 05-31-2007, 02:19 PM   #1167
Spillertwo's Avatar
Yes I think that is the idea behind it. I do think that it makes the belt quite tight for the moment. I wilt test it this weekend if it works properly.
One added advantage is that you can use the one peace engine mount with this tensioner and you can remove it without removing the tensioner.
It works however different than I had expected because I thought I would lose the bearing with it because they can wear out. It turns out however that you have to use them anyway. Maybe nice if Mugen could include some more explanation and fotographs with their products. I am a Mugen fan for sure but sometimes they don't look all that good when you compare it to Serpent. For that brand you can find and download all the info that you want on the internet.
Old 06-04-2007, 05:00 AM   #1168
AMGRacer's Avatar
I am looking for some advice on bodies. I am currently using a Blitz body, the 273mm wide one. Does anybody have any experience with this body, and are there any better ones out there?
AMGRacer is offline   Reply With Quote
Old 06-04-2007, 06:59 AM   #1169
Ryan41's Avatar
Send a message via MSN to Ryan41
I just run a Protoform T530..seems to work fine.. Going to try out the new Shadow though when it becomes available..
Ryan41 is offline   Reply With Quote
Old 06-04-2007, 08:25 AM   #1170
RC-ProSpeed's Avatar
I use Parma Audi R10 is just great...
T530 makes my car a little bit loose on the rear end coming out of the turns.
I hear that Kawahara is great too, but I haven't tryied yet.
RC-ProSpeed is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
