Old 05-29-2007, 10:45 AM   #1141
Spillertwo's Avatar
Hello,
A few posts back I asked a question on how to mount the M-Mod belt tensioner on the MRX4R.
I figured out a way to mount it and took some pictures to let you see. I used some shims to mount it so it touches the belt in the centre of the hammer but I am worried about the upper part of the belt getting warm because it rubbs slightly against the belt tensioner.
Is this the way it should be mounted or does anybody else have another idea ?
Appreciate any help
Spillertwo is offline   Reply With Quote
Old 05-29-2007, 10:56 AM   #1142
gashuffer's Avatar
Trader Rating: 48 (100%+)
That looks bad for your belts.
T-Sal
gashuffer is offline   Reply With Quote
Old 05-29-2007, 10:58 AM   #1143
asw7576's Avatar
Originally Posted by Spillertwo
Hello,
Appreciate any help
I believe you need to remove the carbon fibre tensioner so the M-Mod tensioner can be place deeper ( very close to fuel tank ).
If the belt tensioner still touch the belt, send it back to the shop and ask for refund. It's a junk.
Old 05-29-2007, 11:00 AM   #1144
gashuffer's Avatar
Shouldn't tensioners apply inward pressure? Seems like a belt stripper.
T-Sal
Old 05-29-2007, 11:01 AM   #1145
Trader Rating: 14 (100%+)
it looks like you're suppose to remove the stock belt tensioner. That way, you will have room for the tensioner roller to do it's job.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 05-29-2007, 11:04 AM   #1146
chicky03's Avatar
Send a message via AIM to chicky03
I never seen one used before but I would think you remove the stock one, then still use the ball bearings with the kit. Bolt the bearings to the Mmod in the slot. The bearings should ride on top of the belt like normal.The top and bottom screw go in the normal holes and the 3rd screw in the middle hole goes in when the set screw would go for the handle. You just have to flip the mmod around. Not 100% sure but that is what I would try.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 05-29-2007, 11:06 AM   #1147
asw7576's Avatar
M Mod receiver box also weight like a ballast.
I'm not sure if M Mod is a high performance product or otherwise.
Old 05-29-2007, 11:07 AM   #1148
gashuffer's Avatar
If you shim it out further and install it in where the bearings use to be, will the belt have clearance so the hammer can apply downward pressure? dunno just trying to help.
T-Sal
Old 05-29-2007, 11:47 AM   #1149
Spillertwo's Avatar
Unhappy
Hello,
I tried a few things and here are the results.
First attempt: remove the stock tensionere plate and mount it like that without spacers
-> the belt tensioner doesn't even come near the belt and if you use spacers you get exactly what I already had
Second attempt: mount the belt tensioner on the original belt tensioner plate or use the ball bearings
->doensn't fit due to the way the back end of the tensioner is constructed (you can never line up the two holes with the original tensioner plate) and the bearings are too big
So for the moment the original way without the original backplate but with more shims seems to be the only way I can make it work.
I think it is a very expensive part and you don't get any instructions with it.
Even if it is supposed to be mounted like I figured out, you don't even get the necessary hardware (shims) to mount it correctly.
So I am not to happy with this part at the moment.
Old 05-29-2007, 11:53 AM   #1150
Corse-R's Avatar
The receiver box at least IMHO is junk, had one on my hands and left another time on the shop (could be handy on wet climates were you have lots of water... but not here and not me. If the track is wet, the car remains on the starter box), got the battery holder, just because it weights in the place you can would like an extra of weight, on the lower side.
Love the battery box, but the receiver box, simply I don't like it... now I've seen the belt tensioner and... like the stock one simple, easy and doesn't add more fuss to that zone and one thing less to crush the pipe if someone goes berserk to my car.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-29-2007, 11:54 AM   #1151
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
thats right now put the bearing in the slot and have the top belt going under it so it pulling the tensioner up
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-29-2007, 12:05 PM   #1152
Spillertwo's Avatar
Nitro junkie,
Put the bearing in which slot ? The only hole available is where the screw is to secure the roll bar.
You can not pull the upper belt under the tensioner because it creates way to much tension that way. The belt tensioner hammer is about level with the under part of the belt
Old 05-29-2007, 12:07 PM   #1153
asw7576's Avatar
This is the correct one :
However, don't be surprise if the belt now touch the manifold
If it does, please throw a brick to M Mod for being stupid.
Old 05-29-2007, 12:09 PM   #1154
the slot in front of the M-Mod logo same as the slot on the CF one
Futaba
Mugen
Novarossi
Byron's
Old 05-29-2007, 12:13 PM   #1155
bye the way the names Leonardo da Vinci
Futaba
Mugen
Novarossi
Byron's
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
