Old 05-14-2007, 11:01 AM   #1096
Lil Paul's Avatar
Can someone report on the quality of this new body. I stayed away from the original MSR body because it was was too fragile. I know that these light weight bodies are thinner than normal, but I would rip the body just trying to cut it out and paint it.
Lil Paul is offline   Reply With Quote
Old 05-15-2007, 12:15 PM   #1097
%Yanlei%'s Avatar
I have just ordered two of those new bodies - Aparently they do not have any problems with being overly thin and they drive very nicely...
%Yanlei% is offline   Reply With Quote
Old 05-15-2007, 08:03 PM   #1098
V for Victory's Avatar
Send a message via AIM to V for Victory
Looks nice! I like the V design
SUN VALLEY SPEEDWAY
MUGEN MTX4R-NINJA
MRX4R-NINJA
RTS!
V for Victory is offline   Reply With Quote
Old 05-15-2007, 08:25 PM   #1099
nsupra's Avatar
Just recently saw on the mugen website that they came out with rear universals for the Mrx-4/ Mrx-4 R. Does anyone have any experience with these that they can share? Are they worth it? Any feedback is appreciated.Thanks
http://rctech.net/forum/showthread.php?t=124845&highlight=nsupra
Feedback
nsupra is offline   Reply With Quote
Old 05-15-2007, 09:32 PM   #1100
Is there a major advantage from universals over regular dogbones?
SUN VALLEY SPEEDWAY
MUGEN MTX4R-NINJA
MRX4R-NINJA
RTS!
Old 05-16-2007, 04:53 AM   #1101
azcau's Avatar
When you tear the front end off as I did recently it is much easier to find a cvd in the grass because it has the upright and wheel still attached Dogbone is way more difficult to find.
Mugen MRX5/Novarossi/GRP/Spektrum/RB Fuel
www.MRCCR.com
azcau is offline   Reply With Quote
Old 05-16-2007, 06:22 AM   #1102
chicky03's Avatar
Send a message via AIM to chicky03
I tried them the other day and it seemed like the car had more rear traction but I need to go back to dog bones again to confirm it. I liked them.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 05-16-2007, 06:37 AM   #1103
%Yanlei%'s Avatar
There is less play and therefore a more efficient drivetrain with universals, so a more efficient delivery of power - and they don't pop out so easily like the standard dogbones do on the front of some cars...Although rears dont have this kind of problem.
Another big plus is maintenance work - universals are much more manageable than the standard dogbones as you only have to deal with one side of the dogbone dropping out while performing maintenance.
Lastly, the universals often come in lighter materials like titanium for example.
Old 05-16-2007, 09:59 AM   #1104
need to know
what does the mtx-4r has that the mtx4 doesn't?
The Rookie is offline   Reply With Quote
Old 05-16-2007, 11:09 AM   #1105
%Yanlei%'s Avatar
If you read this thread from the beginning then you will see which parts are different between the MRX4 and the MRX4-R (and the version 2 MRX4-R, H0075).
Or just check the MS website...Check out the MRX-4R there and it will tell you what the new parts are.
Hope this helps...
Old 05-16-2007, 11:34 AM   #1106
RC-ProSpeed's Avatar
Default RD Logics Chassis
Does anyone had try the RD Logics 5mm Chassis....
RC-ProSpeed is offline   Reply With Quote
Old 05-16-2007, 02:40 PM   #1107
Corse-R's Avatar
The universals on the MRX-3 were delicate and almost 100% of the ones who get a pair of rear universals on their Osaka/Millenium version changed them for dogbones who are more resistant to wear and they accept more abuse.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-16-2007, 04:36 PM   #1108
Default wide front belt conversion
Hi,
Could anyone give me details or links of how to convert the front belt to the wider one on the mrx4 ?
xtreme888 is offline   Reply With Quote
Old 05-16-2007, 06:43 PM   #1109
%Yanlei%'s Avatar
Xtreme888, is there any particular reason why you want to perform such a modification?
There are reasons why things are designed the way they are - like why the rear wheels are wider than the fronts
Also, check out the other 1/8 race cars from other manufacturers, I am quite quite confident that the proportions of the belts will be very similar. These cars have evolved to the point that most of them are designed in a very similar manner. It should tell you something about them if they all use the same width belts - they are like that for a reason, and unless you have a really good reason to change it then I think that you should leave them alone.
If your front belt is snapping and your frustration has made you consider such an upgrade, (ie because the rear belt is fine) first check your MRX4 out - it is very likely that damaged, worn or dirty pulleys were the original cause.
Old 05-16-2007, 07:18 PM   #1110
nitrodude's Avatar
I remember reading the MRX3 tread, even though I dodnt have one, and people used to convert to a wider front belt. Maybe thats why he wants to do it.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
