Mugen MRX-4R
#1066
Originally Posted by cdelong
Art Carbonnel showed me what he uses..... the inner tube from a bicycle tire. Get a 26" x 1.75" tube at WalMart for $3 and you'll have enough tubing to cut 100 receiver covers
#1067
This track is just minutes away from the Nation's Capital
RC Pro Series two-day race entry form
Can be submitted at the track on race day.
Capital Classic June 6th-10th
Factory drivers already registered. 160 max. entries. Don't miss this one!
#1068
Originally Posted by moy
you can use the cover from mtx3 or 4,or hpi's recievers box,or those party ballons.
#1069
what do you guys paint you track to make it black?
#1070
Originally Posted by Fred P
I second what Moy said, can't go wrong with the MTX3, 4 reciever covers.
#1071
Guys i need the rear bearing size for Jp fx21 R-03?
Thanks in advance'
Thanks in advance'
#1073
Does anyone know of a blade rear swaybar for the MRX-4R?
Thanks.
Thanks.
#1074
Mugen makes one. I wish I had the part number for you. I used it, but went back to the stock setup. With the blade, even at its stiffest setting it seemed like it was not enough. I would talk to racers that use it at your local track, and get their feedback.
#1075
Thanks.
Thanks.
http://ashfordhobby.com/detail.aspx?ID=1407
-- Wario
#1076
Thanks for the help guys, Thats what i was looking for.
#1077
very nice track right there!! is that the 301?
It's actually not paint at all. It's such a great grade of asphalt that it just shows up that way. It's not my track (I just race there) so i'm not bragging on it, but it's a great track.
I think the contrast with the blue infield paint probably helps!
#1078
screaming engine
hey mugen lovers.got a small problem with my car.at our last club race,i found that the car was intermatently over-revving.2 3rds down our main straight,the car would rev higher than usual for a second or so.my clutch gaps were right.it was so strange.my mates also could not understand why.could it be that the 1way bearing is going?please help!!!!
#1079
check the two speed shoes and the two speed gear hub they engage on. I clean my two speed shoes with scotchbrite pads between race weeks to remove the aluminum build-up on them. check the hub and shoes inside for grooves around the circumference and on the inside surface. do not over-oil those flanged bearings in there. that will get on the shoes/hub and cause slippage.
make sure that the balls in the shoes are tight enough (the set screws on the top and bottom- not the tensioning screws on the sides) and that there is not a lot of play on the hub they mount on. you should just be able to barely move that hub between the shoes.
make sure all your pulley hubs are tight on the shafts as well. sometimes if they loosen they will slip a bit and cause problems like you say. i had the brake hub loosen on the rear shaft and then "weld" itself back in place from the heat.
#1080
thanx for the info.will check on it rite away.
