Old 03-22-2007, 04:08 PM   #961
MugenDrew's Avatar
Trader Rating: 30 (100%+)
For the shocks you can use the mtx-3 front shock spacers or ho181d, caster clip the rear upper hinge pin and use the plastic round washer thats for the front lower wheel base adjustment on the rear lower. I use a 5 dollar miter box/razor saw combo that the airplane guys use for cutting balsa.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 03-22-2007, 05:19 PM   #962
DogboneS's Avatar
Trader Rating: 20 (100%+)
Default wheelbase mod
Can anyone post a pic of the "wheelbase mod". It sounds like you allow the rear upper and lower arms to be moved forward or back to set short or standard wheelbase accordingly across the length of the rear U/L pivot pins.
DogboneS is offline   Reply With Quote
Old 03-22-2007, 08:24 PM   #963
sohlman's Avatar
Trader Rating: 89 (100%+)
Here ya go:
1. Remove 3mm of material from the front of rear upper & lower arms. Also remove a little so the spur gear does not rub on the right arm.
2. Install 3mm spacers behind (to the rear) all four arms. Check for binding issues (possibly not enough material was removed, or they were cut uneven, etc.)
3. Install 3mm spacers on upper body mount as pictured. Again, check for binding.
Done.
I use a belt sander for an even and smooth cut. Then I use 300 grit sandpaper to smooth them out more.
Mugen MRX-4R-mrx4r_cutarms.jpg   Mugen MRX-4R-mrx4r_lowerarm.jpg   Mugen MRX-4R-mrx4r_upperarm.jpg   Mugen MRX-4R-mrx4r_uppermount.jpg
Steve Sohl
sohlman is offline   Reply With Quote
Old 03-22-2007, 08:43 PM   #964
Does anyone have a ling to a Mugen Spring Rate chart or one that they could PM to me.
sikbrahmugen317 is offline   Reply With Quote
Old 03-23-2007, 09:35 AM   #965
GK
Suspended
Originally Posted by sohlman
Here ya go:
Done.
Steve, do you also shorten the front wheel base at the same time?
Thanks!
GK is offline   Reply With Quote
Old 03-23-2007, 09:44 AM   #966
sohlman's Avatar
Thanks!
Yes. No mods for that. Just place the 3mm spacer in the front of the sway bar mounts on the lower hinge pin. Make sure you also put a 3mm spacer in front of the upper hinge pins and measure caster from there. In other words, 4mm of spacers will be 1deg of caster with the setup.
Steve Sohl
Old 03-23-2007, 09:47 AM   #967
GK
Suspended
Thanks!
Old 03-23-2007, 11:58 AM   #968
DanielSon is offline   Reply With Quote
Old 03-23-2007, 12:24 PM   #969
asw7576's Avatar
What do you think of 3racing MRX4 6mm main chassis ?
Too thick ? Too stiff ?
Old 03-23-2007, 03:26 PM   #970
I tried the 3racing chassis last week, The car was very smooth but it did lack some steering at high speed and became a bit doughey.
I tried alot of things to get it dialed but still couldnt get it just right, in my opinion the 0474 mugen chassis is better.
Brendan
mtmmotorcycles is offline   Reply With Quote
Old 03-23-2007, 03:42 PM   #971
Roger's Avatar
Originally Posted by DanielSon
Neimann ?? Where you been ?
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 03-24-2007, 03:09 PM   #972
asw7576's Avatar
Brendan
0474 = stock mrx4 chassis ?
I take your comments as too stiff for 3Racing's 6mm chassis.
Old 03-26-2007, 01:53 PM   #973
Hi there!
I would like to mount an extra fuel filter between the tank and the engine. Could anyone please post a pic of a set-up like this?
Got no clue where and how to fit the little filter...
Many thanks in advance!
fulcrum2 is offline   Reply With Quote
Old 03-26-2007, 02:09 PM   #974
Corse-R's Avatar
Originally Posted by fulcrum2
Hi there!
If you ask for the 'filter' that some we put phisically between the pipe and fuel tank is a pressure chamber. If you do not use it, you can manage to get an off-road fuel filter and getting a spare fitting to keep it on the same place (to get the pieces, you may need to get the pressure chamber), route the fuel line from tank to filter and to the carb nipple.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 03-26-2007, 04:52 PM   #975
wario69's Avatar
Hi there!
I only use Mugen's Air filter MUG B0104 (between tank & engine)
and
Mugen's Pressure Chamber MUG B0116 (between tank & pipe)
this comes with a mounting set so you can mount as you please to make it all neat). I'm at work right now and don't have access to my pics. Do a search for pictures in this forum. The last time I did that I saw plenty of fuel filters and pressure chambers.
-- Wario
wario69 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
