Old 02-28-2007, 08:32 PM   #901
quietstorm76's Avatar
Originally Posted by mrgsr
rear toe as per manual
5.5 block i believe the stock one
protoform t530 but ill be uisng the kawahara body this weekend as the other one was getting a bit shabby
Try the Kyosho Dome body. Mount it forward about 10mm.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 03-01-2007, 02:33 PM   #902
I need some help adjusting my mrx-4r clutch.
The clutch engages right when my car starts, I need to adjust to clutch so the car can idle without the clutch engaging. The idle adjustment isn't the problem, the engine idles at a normal level.
This mrx-4r manual isn't helping.
Thanks.
dubcast is offline   Reply With Quote
Old 03-01-2007, 03:22 PM   #903
Ron C.'s Avatar
Thanks.
Double check and make sure there is enough gap between the Clutch Bell and the Clutch Shoe... I suggest using one of the thick washers from a Thrust Bearing Set and place it before the bearing behind the clutch bell.
The idea is to have the clutch bell spinning freely (without any bind with the clutch shoe). You may add shims after the Thick Washer as needed, in order to create a good gap.
From here, you may complete putting the rest of the clutch assembly.
Also make sure you have the correct end bell play when everything is complete. I usually maintain 0.4 mm end bell play.
Lastly, at this point you may start adjusting the Clutch Nut in order to set the right clutch engagement you prefer.
Let us know if this works.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 03-01-2007, 10:49 PM   #904
Turns out I had the clutch assembled wrong. I didn't notice that you had to thread the clutch nut onto the flywheel nut. I just dropped the spring and nut in there and didnt bother tightening it.
After finally managing to get the clutch nut onto the flywheel nut, it's working properly.
Old 03-02-2007, 07:33 AM   #905
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by Lil Paul
not meaning to be a pain either, but Mike it would be nice if we can see some setups that are more current. Maybe something from the Nats or Winternats.
Most of the time everyone runs the stock setup with a few changes. Here is a link to the setup.
http://www.mugenseiki.co.jp/mugen/menueefi.htm
What is changed most of the time is we run the 4.5 rear block, castor(either more or less), short front wheelbase always, and use the shortest rear camber link(the one without the inserts). On the upper arm position you can add a 1mm shim and that seems to smooth out the turn in and gives the car more middle out. It seems to me it helps in sweepers and carosels. The 1st gear pinion is always 16t. I try and mess with the front swaybar but I always go back to flat. Moving the body mount arm out will give you more traction. You can also try different shock oil. In the rear stiffer gives more turn in use 600-800 and in the front for parking lot tracks I go to 500 sometimes.
On parking lot tracks where there is no sealer and sugar water for traction spray you can try grey front springs and take off the front sway bar.
The biggest improvement or handling change to me seems to be tire shore. If you don't have the correct tires all of the other stuff will not matter.
It is not a setup sheet but at least you know what is currently being run on most tracks.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 03-02-2007, 08:15 AM   #906
Ron C.'s Avatar
Glad to know it's working properly dubcast... Have fun!
Old 03-05-2007, 03:48 PM   #907
can someone offer some help? i'm using the tweak station on the hudy system to measure track width. and the setup sheet calls for front=252mm and rear=263mm. what reading should i be getting?
i'm new to this so and any help would be great!
Thanks...
racer2 is offline   Reply With Quote
Old 03-05-2007, 03:57 PM   #908
sohlman's Avatar
Trader Rating: 89 (100%+)
Thanks...
Easiest way to measure your track width is by using a large caliper or just line it up on the hudy board. Remember, front wheels: only adjust the bottom king pin and the rear wheels: the back king pin. The others are for camber (front) and toe (rear). And that both sides are exactly the same.
Steve Sohl
sohlman is offline   Reply With Quote
Old 03-05-2007, 04:09 PM   #909
Old 03-05-2007, 04:25 PM   #910
sohlman's Avatar
front/rear king pins? where is that located?
They also call them pillow balls. They are the large ball studs inside your front and rear uprights. They screw into the suspension arms.
Steve Sohl
Old 03-05-2007, 04:27 PM   #911
ohh! okay!
Thanks for the help!
Old 03-05-2007, 09:21 PM   #912
cdelong's Avatar
Default MRX-4R kits
What's included in the latest kits out?
Last I knew the latest kits included the option chassis, new front steering blocks with the scrub settings and the option rear arm mounts.
Anything else different currently in the kits? Engine mount?
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 03-06-2007, 11:18 PM   #913
Lil Paul's Avatar
This could be old news, but the lower front and rears arms are different. It seems that they moved the shock mounting hole out a little bit. The good is, Mugen is constantly trying to better car; the bad is, they need to change the part numbers when a part is changed. I have brought spares recently, and had spares that were purchased a while ago. So if you do not pay attention or someone does not tell you, there is no way of knowing with just looking at the part number.
Lil Paul is offline   Reply With Quote
Old 03-06-2007, 11:21 PM   #914
PROVK's Avatar
Trader Rating: 14 (100%+)
Whats the difference betweem MRX-4 uprights and MRX-4R uprights.
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 03-06-2007, 11:48 PM   #915
Pooh2's Avatar
Send a message via MSN to Pooh2
Paul, it says this on the box when u got it"*The contents are subject to change without notice due to
product improvements and specification changes". Part of da game baby!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
