Old 01-08-2007, 07:58 AM   #631
Chewdogg's Avatar
Sohlmans right...Depending on how old your 4 is it may be better to sell the old one and buy a new kit. I had the original 4 and I changed a lot to get it to the R spec. And I still end up just buying a new kit(just wanted a new car). Here is what I found to be different. It may be more but I think this is close.
front upper arms
front lower arms
front upright
axle spacers for front upright
spaces for turnbuckles
front bulkhead
front shock tower
rear upper arms
adjustable rear hingepin holder (not quite sure what its called)
spacers for hingepin holder
rear shock tower
rear shock bodies
rear body mount
rear bulkhead
chassis (the optional one for the regular 4)
MAX POWER AMERICA
Chewdogg is offline   Reply With Quote
Old 01-08-2007, 11:01 AM   #632
Trader Rating: 52 (98%+)
Default Thanks guys
Thanks guys.
One of my mrx4 is brand new, it is so smooth that I hate to get rid of it, the other one is about 1 gal old. I also have two mrx3 works edition that I normally practice with so not much use on mrx4.
so anyone has a new 4r for good price? I seen them on ebay NIB for $400.
straightaway is offline   Reply With Quote
Old 01-08-2007, 11:07 AM   #633
Originally Posted by straightaway
Thanks guys.
so anyone has a new 4r for good price? I seen them on ebay for $400.
I have spare one that i have been trying to sell here.
are you going to the winternats??i can bring it with me so you can look at it.
AKSHUN is offline   Reply With Quote
Old 01-08-2007, 11:17 AM   #634
cdelong's Avatar
Thanks guys.
I wouldn't buy much off ebay.... usually you have to spend $100 for new belts, gears, pulleys, and other consumables, etc....
Just buy AKSHUN's 4R and you'll be all dialed in- it's like new. He has a good maintenance schedule
Now if you need engines, come and see me
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 01-08-2007, 11:18 AM   #635
quietstorm76's Avatar
For me the conversion was really easy and quick. The day before I converted I just tore the car down, the next was just a build and test day. The only thing I don't have is the chassis which I need for the added wieght. Total cost to convert was about $130.00 minus the chassis. I got everything from Winner's Circle. It was just cheaper for me to convert since my 4 only had 3 races on it.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 01-08-2007, 11:20 AM   #636
cdelong's Avatar
Originally Posted by MugenDrew
Akshun I putt em on before the car hits the track, helps keep tares around the front body mount holes. Something else Ive been doing for years that works like a snake charm; Lexan radio box tape (boat and airplane guys). Put it on areas that are likely to crack and thin areas on the body and under your body brace screws or rivets. It goes on the outside of the body(its crystal clear) and wipe the areas your applying it to with denatured alcohol before you apply it. It has to be put on before the body ever gets run.
I imagine thery're also lighter than the fiber tape and shoe goo I use underneath the body. I may have to start using those Parma deals.
KYOSHO EVOLVA
35PLUS21
Old 01-08-2007, 11:21 AM   #637
Thanks Mugendrew, i think ill put one on each of the front wheel fenders, seems to be the first place they crack for me.
i painted and mounted the first body, i used the the holes closest to the back and i still think it could be lower.
im using the short mounts in the rear, and the short mounts with two shims in the front, ride height is 6mm rear,5mm front and tire diam is 72 rear, 65front(old tires)
along the side it starts high in the rear and declines to the front.
im painting the second body, but ill leave it untrimmed.
are you going to the winternats??if so, im wondering if you could look at it and help me mount it properly, maybe theres something im overlooking.
thanks,
steve
Old 01-08-2007, 11:30 AM   #638
Corey, thanks for the compliment, i wish i had the meticulous motor skills that you have.
maybe its your break in (cyrul method) or the time you spend on them.
ive got an engine for ya to look at, it needs some TLC.
Old 01-08-2007, 11:52 AM   #639
cdelong's Avatar
Which one? If it's one of those Collari's leave it home. We've struggled with those 2 years straight with no luck at all. Otherwise I'll look at it- if it's suspect at all I'll give you a "loaner" from the fleet if you need one.
I'll sell you the R-01 you ran in Hamilton (still way tight), a NIB 321P or a just broken in R-03.
Step #1- PM me if it has any pinch left with the plug removed.
KYOSHO EVOLVA
35PLUS21
Old 01-08-2007, 02:24 PM   #640
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Akshun pull your tires off, front short mounts no spacers. With the body on hold a straight edge to the bottom of the chassis and run it around the bottom of the body. It should touch everywhere but behind the rear wheels.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 01-08-2007, 10:26 PM   #641
asw7576's Avatar
Originally Posted by sohlman
Sometimes it's easier to just sell the 4 you have and get an R. The amount of parts needed to convert is larger than you think (don't forget rear shock bodies, shafts, both shock towers, clutch shoes etc.). The work it takes to convert is almost as much as building a new R. Especially if you plan change the bulkheads. Plus, it depends on how old your 4 is. There are always "running" design improvements with all Mugen cars and parts. Most of the time they are very simple and you don't notice, but they help a lot. I know there were many with the 4 so you may never know if you have the latest stuff. jm2
I learnt the hard way.
Never upgrade a car when the cost of upgrade is almost half of brand new.
Old 01-09-2007, 01:57 AM   #642
Thanks, ill try that.
Old 01-09-2007, 03:55 AM   #643
feroz's Avatar
Default engines.
hey guys.i think i need 2 b shot.just bought a R03 as well as a R01 stock version.(silver crank case).R03 was a full house with ceramic bearing and factory run-in.i checked on the website,R6 conrod.any views?should i get one?
Rovan baja 29cc, SavageX 4.6 stock, SavageX Z28R spec3, SavageX Alpha.28,
MRX4X Collari 35+21, MRX5 Collari 35+21, serpent 835 rwd RB X15,
Revo 21 TM, TMAXX 3.3 stock, Jato 3.3 stock, schumacher nitro fusion .28, JR Z1 DSM.........
feroz is offline   Reply With Quote
Old 01-09-2007, 11:19 AM   #644
The R6 conrod is the lightened one with the special hardened wrist pin.
they are supposed to improve the bottom and top end.
but unless your a pro, lookin to shave off tenths of a second, then i couldnt justify the cost.
Both of those motors are excellent right out of the box, try and get the full potential out of them the way they are, then go with the new rod once you have mastered the insane power that you already have.
One of the guys on here also has those motors for sale, real cheap and if your interested i could get him to pm you.
Old 01-10-2007, 05:49 AM   #645
feroz's Avatar
Default reply
thanx for the info Akshun.also thanx 4 letting know about those that r 4sale.the next motor i buy,will b a Murnan mod motor.preferably a ninja or 35+21 with ceramic bearings.hopefully in this year.what r ure views on those motors.i checked the forum on saturday.he mailed me already
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
