Old 01-01-2007, 12:03 PM   #601
serpentpro28's Avatar
Guys where can i get a piston and sleeves for jp 21 r-03?
Thanks in advance and Happy New Year to All'
Team bilis racing
serpentpro28 is offline   Reply With Quote
Old 01-01-2007, 12:40 PM   #602
cdelong's Avatar
Originally Posted by sohlman
Both body mounts should work. It depends on how you want the front end to handle...more or less front steering.
Before you make your final decision on a body, the Mugen "Whip Two" is coming. It's being developed right now with even more front steering.
Lower mount= more steering? Higher mount= less??
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 01-01-2007, 12:55 PM   #603
Corey , im guessing its a ride height thing, depending what you are set at.
this body has a pretty steep front end, similar to the blitz.
well, if its good enough for Burch, its good enough for me.
AKSHUN is offline   Reply With Quote
Old 01-01-2007, 03:46 PM   #604
cdelong's Avatar
I dunno either. I just figured if the front of the body was lower using the low mount, more air would hit the front face of the body.
I get all hosed up on this technical stuff. I just wanna drive. You wanna set my car up
Maybe since Sohlman ain't gonna drive we could just hire him for some beer to set us up
KYOSHO EVOLVA
35PLUS21
Old 01-01-2007, 03:53 PM   #605
cdelong's Avatar
Ron or Mike......
you guy's bringing some Whip Two's for us guys in the pits?? We'd all like to try them, but distributors may not have them in time if it's down to the crunch.
Thanks.
KYOSHO EVOLVA
35PLUS21
Old 01-01-2007, 05:00 PM   #606
MugenDrew's Avatar
Trader Rating: 30 (100%+)
R 10; the rear dots that line up with the rear body posts in there forward position will set the front end 10mm from the front bumper. The front mounts wont line up with the dots because "they did not know" that the body mounts on the car are eccentric. Run the short front mounts in there forward position(there dots will be 3mm be hind the posts) and the short rear mounts outside hole with the wing down. Parmas lower cut line is perfect set up this way, even with the bottom of the chassis all the way around. If it drags use the 2mm spacers under the front and switch to the tall rear supports. Should not drag a the FT. with 5mm or higher front ride height.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 01-01-2007, 07:06 PM   #607
Thanks mugendrew, thats exactly the info i was lookin for.
Old 01-01-2007, 07:44 PM   #608
sohlman's Avatar
Trader Rating: 89 (100%+)
Beer works for me! But your setup may suffer a bit...
Actually, it has to deal with moving the body forward or backward to get more or less front steering. Remember the front of the new bodies (Whip, R10, etc.) are sloping up. If the body is forward, you will need a taller body post...and vice-versa if the body is back. I keep about a 10mm gap between the front lip of the body and the plastic bumper and I have plenty of steering...with the Whip.
AKSHUN: Yes the first Whip had lighter lexan, but the performance was incredible (compared to the T530, Dome and the Kawahara on a R). I'll bet you will be happy with the Whip II...or what ever the name will be.
Steve Sohl
sohlman is offline   Reply With Quote
Old 01-01-2007, 07:51 PM   #609
Thanks sohlman, im gonna buy a couple at the winternats and ill use them in the summer months when our season starts.
I might head out to the Toledo track and test both of the bodies on one of their club days, they have a pretty nice surface.
Corey, you up for another road trip after the winternats???
Old 01-01-2007, 08:54 PM   #610
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
IS the Whips that much better than the T530 despite being much lighter and more "fragile"?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-01-2007, 09:01 PM   #611
They provide more downforce and better handling, more agressive.
Old 01-02-2007, 07:55 AM   #612
MugenDrew's Avatar
The thin rear did not turn out to be a problem for me. Yeah it got crinkled up but I have not had one fall apart. I'm running the 10 while waiting for the new Mugen body and it is good. I don't know how pro-line is pulling the 530 as it is the only wedge body I've run across that was not thin in the rear. Any of these new bodies is Superior to the Lola. Look at your lap times.
Old 01-02-2007, 06:34 PM   #613
HarKonnenD's Avatar
Sounds good. I guess this is the body to get as well as upgrade my MRX4.
Old 01-03-2007, 12:57 AM   #614
feroz's Avatar
Default lola
happy new year 2 all u rc fanatics.what r the different types of bodies that u guys r running?im running the protoform 530.no problems.i use the wing and the re-inforcement braces
Rovan baja 29cc, SavageX 4.6 stock, SavageX Z28R spec3, SavageX Alpha.28,
MRX4X Collari 35+21, MRX5 Collari 35+21, serpent 835 rwd RB X15,
Revo 21 TM, TMAXX 3.3 stock, Jato 3.3 stock, schumacher nitro fusion .28, JR Z1 DSM.........
feroz is offline   Reply With Quote
Old 01-03-2007, 01:57 AM   #615
were talking about the new Parma R10 and the mugen "whip " bodies, they provide way more downforce , thus giving the car better control under more power.
try one of these bodies out and you will notice a huge difference right away.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
