Old 12-19-2006, 06:26 AM   #556
feroz's Avatar
Wink novarossi 35 plus21
how does the nova 35+21 compare to the jp r03 with ceramic bearing and r6 conrod?my dad has 1.that is the sh..!that baby goes.
Rovan baja 29cc, SavageX 4.6 stock, SavageX Z28R spec3, SavageX Alpha.28,
MRX4X Collari 35+21, MRX5 Collari 35+21, serpent 835 rwd RB X15,
Revo 21 TM, TMAXX 3.3 stock, Jato 3.3 stock, schumacher nitro fusion .28, JR Z1 DSM.........
feroz is offline   Reply With Quote
Old 12-19-2006, 02:30 PM   #557
There was a bit of a rumour that the 35+21 has a hard time making the 5 minute mark with the legal amount of fuel, Is this true???
mtmmotorcycles is offline   Reply With Quote
Old 12-19-2006, 03:24 PM   #558
I have a few of the full option FX R-03's and they are about the same, the JP is slightly faster in top end and better on fuel mileage.
AKSHUN is offline   Reply With Quote
Old 12-19-2006, 07:29 PM   #559
quietstorm76's Avatar
Default 25T side pulley
Anyone have a solution for the loose belt when using the 25t pulley? I have the tensioner as tight as it can go.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 12-20-2006, 03:12 AM   #560
Change the belt, its too stretched out.
Old 12-20-2006, 04:27 AM   #561
I didn't think it was stretched but I'll put on a new belt today. I hope it works, Thanks
Primary Weapon: ?
Secondary Weapon: ?
Old 12-20-2006, 03:26 PM   #562
Quiet storm, i am only guessing that it is stretched cause i have tried the 25tooth pulley and i know it may make a noticeable difference, but it should still be somewhat tight when using the tensioner.
another thing, the 25 tooth is too low, unless your running on an extremely small tight track , i wouldnt recommend using it anyway
Old 12-20-2006, 04:47 PM   #563
I'm running it because I'm experimenting with small tires.
Primary Weapon: ?
Secondary Weapon: ?
Old 12-20-2006, 06:23 PM   #564
sohlman's Avatar
Trader Rating: 89 (100%+)
Just a general statement:
Quietstorm, I applaud you trying different things like smaller tires. If you got the time, there are so many different things you can try that the setup sheets don't show...no overdrive, body position, wing height, pipes, manifolds, clutch set up, tire split, tire camber, bearings, shift points, not to mention radio tuning, etc., etc. And some of these things may or may not compliment your driving style. This is one of the reasons Mugen USA does not always update their setup sheets...because sometimes the setup on the sheet doesn't change, other things do. But it's a great feeling when you find something, or the right combo of things and your game steps up to the next level. Great to see people doing things out of the norm. That truly is the spirit of this hobby and maybe way I'm so addicted to it. Happy racing in 2007!
Have a great holiday season everyone.
Steve
Steve Sohl
sohlman is offline   Reply With Quote
Old 12-21-2006, 06:17 AM   #565
Winner's Circle's Avatar
I predict that the car will push with a 25t pulley due to the front tires spinning.
Spinning tires = no traction.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 12-21-2006, 06:22 AM   #566
Default overdrive ratio chart
I have an Excel spreadsheet set-up to compute overdrive ratio based on the pulleys on the car and the tire diameter. This spreadsheet allow you to change the number of teeth on the pulley and see the impact that this change has on the front to rear overdrive ratio.
If you would like me to email a copy of this go to
http://gasrccar.com
and click the EMAIL US link at the bottom of the first page.
Lee Muse
[email protected]
Old 12-22-2006, 03:03 PM   #567
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Yep any movement of the wheel it will be a dart before the suspension takes effect, once the suspension starts to work the push monster will arrive! Have fun, lots a stuff to test; run the a setting on ackerman then change to the d. Ye ha easy on the throttle with the d.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 12-22-2006, 06:16 PM   #568
Thanks for the tips winner's circle and mugendrew. I'm happy with my current setup, I'm really just trying to use up some small tires I have.
Primary Weapon: ?
Secondary Weapon: ?
Old 12-26-2006, 08:43 AM   #569
What type of belts does everyone run? Rubber or urethane?
Mark Unger is offline   Reply With Quote
Old 12-26-2006, 09:23 AM   #570
sohlman's Avatar
Rubber belts = smoother drivetrain.
Steve Sohl
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
