Old 11-03-2006, 10:30 AM   #436
tunerjetta29's Avatar
I looked closer and see the difference in the holes now. The Servo travel is fine, full travel and equal L-R and the servo is quick its a Hitec Coreless HS-965MG - Ultra Speed.
tunerjetta29 is offline   Reply With Quote
Old 11-03-2006, 12:13 PM   #437
MugenDrew's Avatar
Trader Rating: 30 (100%+)
The lower arm position makes the largest change to roll center and you have it at the lowest setting(more roll =more side bite). Unless the track is garbage you should not need anymore than 1.5 degs toe in in the rear. So maybe ya got to much rear end bite. Rons sett-up is NICE, shes a happy rotator...
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 11-03-2006, 12:38 PM   #438
I didnt think about the rear roll center affecting the off throttle steering so much but i guess thats quite possible since i havent tried to adjust it yet. As far as the rear toe goes im sure it is too much as the track has a lot of traction, i just was experimenting and found that the settings i stated gave me the best feel/times, but still left me with the push issue.
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
Old 11-03-2006, 02:58 PM   #439
Corse-R's Avatar
That's one of those things that amazes me from the US Tracks to tracks we run at the other side of the pond. You guys use tyres a lot harder (40 shores are usual there) and go with very small rear toe-in. I suppose that's a side effect of putting sugar and sticky things on the track.
I can hardly recall the last time I used a 40 shore the most used compound here are 35's and sometimes 37's and maybe not on all the car (maybe only a tyre or two on the outer side just to compensate tyre wear).
BTW: Revelation seems to be a small track (gearing) with some ripples (ground clearance with the tyre sizes) is that true? Why not use a shorter rear upper arm and maybe some stiffer spring (pinks) if you need a car who likes to turn, this maybe is the target, a stiff rear and maybe a soft front.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 11-03-2006, 03:18 PM   #440
MugenDrew's Avatar
www.revrace.com . My own experience with my own clutch set ups is that if toe in is higher than 1.5 the damn thing pushes bad coming out of the corner. I wish the tracks in Florida were sticky enough to run 40's...
Old 11-03-2006, 05:36 PM   #441
cdelong's Avatar
Ron,
You going to the WinterNats? What rear block should I start with at Ft. Myers- 4.5mm? I'll be looking you guy's up for some help down there.
Corey
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 11-05-2006, 02:48 PM   #442
Originally Posted by Ron C.
Hi tunerjetta29,
Here's the MRX-4R set up we ran during the recent Kyosho Championship Race @ Revelation Raceway:
Front Suspension:
Track Width : 250 mm
Ride Height : 6 mm
Camber Angle : -2.0 mm
Toe : 0.5 mm OUT
Rebound Stop : 0.0 mm
Bump Stop : Not used
Wheel Base : Short Wheelbase Setting
Upper Arm Spacer : 2.0 mm
Upper Arm Holder Position : 1.0 mm
Sway Bar : 45 degree angle
Front Shock Oil : Mugen 600
Front Shock Spring : Mugen White
Front Shock Piston : Stock
Front Shock Position : #2
Rear Suspension:
Track Width : 262 mm
Ride Height : 7.0 mm
Camber Angle : -3.5 mm
Toe : 1.5 mm IN
Rebound Stop : 8.0 mm
Upright Spacer : 2.0 mm
Rear Block : 5.5 mm
Sway Bar : Stock @2.5mm forward
Rear Upper Arm : Long Setting
Rear Body Mount : Outer position
Rear Shock Piston : Stock
Rear Shock Oil : Mugen 700
Rear Shock Spring : Mugen White
Rear Shock Position : #2
Steering Ackerman : B position
Rear Tires : GRP 40 (74.0 mm)
Front Tires : GRP 40 (67.0 mm)
Clutch Spring : MSR Spring
Clutch Pad : Gray
Clutch Cen Shoe : Light weight
Clutch Nut Position : 9.2 mm
Clutch Bell Clearance : 0.4 mm
Gearing : 1st (16/49)
2nd (20/46)
Hope this helps ...........
Alright, i ran this setup today, the only thing i did differently was i was running 45 shore F/R and i am still running the rear 4.5 blocks instead of the 5.5
The car had good turn in, but the rear was very "hoppy". Mid corner i would notice the car 3 wheeling (inside rear wheel off the ground) and the car would hop. I tried moving the ball ends further in on the rear sway to reduce the rear roll, but no luck. What would help sure this? Is it possible that switching to the rear 5.5 block will solve the hop? Any info would be appreciated!
Currently Running:
Ko Propo EX-1 V3
Old 11-05-2006, 11:13 PM   #443
asw7576's Avatar
I touch my friend's front wheel hub ( where you lock the front tires )..... it's very2 hot
I guess the shims cause it.
Old 11-05-2006, 11:28 PM   #444
Pooh2's Avatar
Send a message via MSN to Pooh2
Try running the rear 263. That will help the car slide a lil more.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 11-06-2006, 09:27 AM   #445
Ron C.'s Avatar
Put on the 5.5 and it should help rid the "hop".
Also double check to see nothing on the rear suspension is binding whatsoever. I typically disconnect the dampers and slowly lift the left suspension from the rear hub and observe how the right side reacts in respect to it. And Vice-Versa. From there, it should show if all points are moving Freely and Evenly or not as this could also contribute to the car hopping. But Im glad to hear you found good steering from the car now.
Was there a lot of bite when you were there, hence you used 45s?
Revelation is a fun track / facility to race at but conditions may also be a bit tricky. It's almost like constant fine tuning is needed to get optimum performance from the car. Aside from this coming weekend, let me know when you will be out at the track again and I will head out there to run with you. Let's try to get your car where you feel most comfortable and Fast around the circuit.
I'll PM you my email address so I may respond to you quicker.
See ya soon!
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 11-06-2006, 09:35 AM   #446
Ron C.'s Avatar
Originally Posted by cdelong
Ron,
Corey
Hi Corey,
We have plane tickets already
About the set up, we both gotta rely on Mikey for that.
It's all good - see you soon !
Old 11-06-2006, 09:44 AM   #447
See ya soon!
Thanks for the info. The track was very grippy which is why i went with 45's. A lot of people have told me they never drop below 40 anymore at Revelation, and that 45 is normal as well. Ill try the 5.5 rear blocks and see if it helps. If it doesnt i may throw the stiffer springs back on the rear to see if i cant get it to slide more smoothly. I did check and I know the rear isnt binding, I went through the whole car last weekend and made sure that everything was functioning properly. Thanks for the info, an it would be great to see you at the races!
Currently Running:
Ko Propo EX-1 V3
Old 11-06-2006, 10:15 AM   #448
Trader Rating: 15 (100%+)
What is ( rear 263)?
THE DOCTOR is offline   Reply With Quote
Old 11-06-2006, 10:18 AM   #449
YBSLOW's Avatar
Rear track width in millimeters.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 11-19-2006, 05:05 PM   #450
quietstorm76's Avatar
Hey guys I'm currently running an MRX4 standard and I have no complaints. I was wondering if it's worth converting to an 'R'. All the parts will cost about a 100 bucks or so.
My question is how will the handling be effected if I use the regular chassis with the conversion? Any opions will be appreciated.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
