Mugen MRX-4R
#362
Originally Posted by Adim_X
For any of you guys using the blade type rear sway bar I have a question. What setting is closest to stock. I think the stiffest setting would be perpindicular to the ground. THanks for the help!
Noted that the word "closest" is used because, the Stock Sway Bar would still be stiffer than the Blade S/B even when the Blade S/B would be at it's stiffest settting.
#366
Hi guys, I am assembling my MRX-4R and I am lost on a few things. There was a single yellow page titled "supplement manual" that was included with the documentation in the kit. On that page were some assembly instructions which differed from the normal manual and I can't decide which way is correct.
Do you guys assemble your MRX-4R the way the supplement manual says or the way the original manual says? There are some small differences and I have never built one of these cars and I want to do it the right way.
Thanks.
Thanks.
#367
build it to the yellow page, its referring to the new front uprights and the 1mm shim that must be installed under the steering rods i believe.
#369
Make sure the bearings are tucked in ( or plug in ) inside the steering upright correctly.
The wheel hub's pins for rear wheels and front wheels are different in length. Front is shorter.
#372
Don't use too many shims. It will be too tight and it could damage the bearings. Use 1 shim on CVD side and 1 or 2 shims on outside.
#375
im looking closely at the photo, it looks to me as if the bearing is not seated properly, try making it rest flush with the upright.
it seemed to fit ok on mine.
