Old 09-10-2006, 05:14 PM   #256
Corse-R's Avatar
Originally Posted by asw7576
I use supa killa servos Hitec 5955TG. Hail to King of torque ( 333oz / 24kg )
Why such beasts? those servos are more suited to the steering of a truggy or a 1/5 scale steering.... with 8-10Kg you're more than what you need... more is overkill. Nothing best than a pair of 9450/9451 Futaba servos for any kind of gas car...
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-11-2006, 05:53 AM   #257
Trader Rating: 13 (93%+)
Default stock shock oil..
what does the standard 600wt shock oil convert to in normal shock oils hehe..
eg: 40wt 50wt etc..
thanks guys
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-11-2006, 06:04 AM   #258
sohlman's Avatar
Trader Rating: 89 (100%+)
eg: 40wt 50wt etc..
thanks guys
John
600wt = 60wt. Just remove the zero, another eg: 350wt = 35wt.
Steve Sohl
sohlman is offline   Reply With Quote
Old 09-11-2006, 06:19 AM   #259
thanks sohlman i knew it was something simple
im just trying to understand my car a little more
its the mrx4..
i can get my rrr to handle sweet at any track
i just dont have much experience with the 1:8, ive only had about 30 mins of track time with it
Old 09-11-2006, 10:26 AM   #260
asw7576's Avatar
Originally Posted by Mugen4lyf
im planning to buy a transmitter but im thinking about KO PROPO EX-10 Helios Competition Version 27MHz or M11 any idea or comment? pls....
It's your choice
I pick KO propo for myself. The best ergonomics so far.
Old 09-11-2006, 12:51 PM   #261
Corse-R's Avatar
AFAIK wasn't a matter of removing just a number... a #600 from Mugen is equivalent to a #55 from Team Losi and such... is a slight difference between the US made silicones and the others (and of course... don't mess with the Snake ones in cst... totally different units - you can end with a nightmare in your mind).
I have a bottle of #500, #600, #700 & #800 from Mugen and never had a problem with them... maybe are a little expensive, but...
Cheers,
Corse-R
Old 09-12-2006, 01:32 AM   #262
asw7576's Avatar
Just stick with 1 brand.
Old 09-12-2006, 03:47 AM   #263
we cant buy the mugen oil locally, ive been using the gs racing oils
Old 09-12-2006, 04:51 AM   #264
Trader Rating: 15 (100%+)
eg: 40wt 50wt etc..
thanks guys
John
That is not a easy question to answer. Assoc., Losi, and Trinity's shock oils are not the same even in the same 30W oil. I asked this same question about a year ago on the MTX-3 thread and someone posted a site that checked all of the major brands. When I looked at the results I was shocked to see the variations in any one brand. Losi was the closest on the actual weight that was stated on the bottle and Trinity was the worst.The way that Mugen shows the oil weight is more accurate (finer graduations). The best thing to do is to just stick with one Company for all of your oils like asw7576 said and you will be consistant when you want to make a shock oil weight change.
THE DOCTOR is offline   Reply With Quote
Old 09-12-2006, 02:40 PM   #265
asw7576's Avatar
Anyone use 25T front side pulley ?
The default is 26T.
What is the effect going down from 26 to 25 ?
Old 09-12-2006, 02:43 PM   #266
Corse-R's Avatar
The default is 26T.
Depending on which pulley you choose you'll need to use 7mm or 9 to 10mm of tyre split. This is the main difference. Those sets are so expensive that the idea of killing my front tyres up to 64 or less mm horrorizes me.
Cheers,
Corse-R
Old 09-13-2006, 12:44 AM   #267
asw7576's Avatar
Which pulley to use so I can drop in the tires out of the box ?
GQ tires is 7mm split difference out of box.
Old 09-13-2006, 11:22 AM   #268
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Red face
Simple question, very complicated answer. I'll try and keep it simple. #1 The smaller the tire diameter the more reactive or responsive or twitchy it will be with a little less side traction. Larger dia. more stable and a little more side traction. #2 Look at the roll out chart, select your desired rear dia. and follow over to the number closest to 1.000. At 1.000 your rear tyres and front tyres will cover the same distance per engine revolution, and this means that 4WD will always be ingauged. As the number goes higher like 1.025 the car will behave more and more like a front wheel drive car than 4wd IF the front belt can take it. The lower this number .998 the more the car will act like a rear wheel drive car. The rears cover more ground per engine revolution than the fronts and because of our wonderfull front one-way power will not be applied to the front. However if the rears slip(Little to hot coming out of a corner)the one-way will engage 4wd to help pull the car out of the corner.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 09-13-2006, 01:06 PM   #269
YBSLOW's Avatar
Originally Posted by MugenDrew
Simple question, very complicated answer. I'll try and keep it simple. #1 The smaller the tire diameter the more reactive or responsive or twitchy it will bewith a little less side traction. Larger dia. more stable and a little more side traction. #2 Look at the roll out chart, select your desired rear dia. and follow over to the number closest to 1.000. At 1.000 your rear tyres and front tyres will cover the same distance per engine revolution, and this means that 4WD will always be ingaged. As the number goes higher like 1.025 the car will behave more and more like a front wheel drive car than 4wd IF the front belt can take it. The lower this number .998 the more the car will act like a rear wheel drive car. The rears cover more ground per engine revolution than the fronts and because of our wonderfull front one-way power will not be applied to the front. However if the rears slip(Little to hot coming out of a corner)the one-way will engage 4wd to help pull the car out of the corner.
One of the best explanations I've seen.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 09-13-2006, 03:01 PM   #270
asw7576's Avatar
Nice, thanks
I'm going to keep the ratio close to 1.000 but no more than 1.000
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
