Old 10-16-2008, 10:51 AM   #1531
wmay11's Avatar
[*]Spring, I use super hard spring and tighten it about 1mm from the tip of the nut.[*] this is the important part. setting your gaps. Once most of your clutch is all assembled I take the clutch bell with both bearings in and place it onto the crank. The crank pointing towards you, and you looking down at the bell, you spin the bell. You will see that the bell binds against the shoe. [*]place shims on the crank and start shimming from the inside ( FROM the clutch nut). [*]Put one shim in and spin the bell, if it still binds against the shoe, add another. [*]After a couple of shims you feel that your bell is not binding against the shoe, this means that the inside gap is set. The advantage of this way is that the shoe determines the gap, after a couple of heats you will find you need to redo this as you wear your shoe out. Fool proof bro. [*]assemble thrust bearing, make sure that the larger hole of the thrust plate is closest to the motor. [*]Do your end play shimming. [*]I have my endplay between .3 and .5, once again the bigger the gap, the more punch you will have. [*]Always make sure your thrust bearing has the correct lube on, and that you lube it often, very quick and can saves you from loosing a heat or a bearing. [*]Also the lighter the clutch weights are the more punch you will have as the motor needs more RPM to kick them out against the pressure plate to engage the clutch.[*]Hope this helps, I found it to be fool proof and my clutches are consistent and predictable.
Hope this helps, I am not a pro but I have ever had issues with clutches going, but each one has there style of doing things, this just works for me.
All the best man!
Warren
wmay11 is offline   Reply With Quote
Old 03-15-2009, 12:01 PM   #1532
Trader Rating: 16 (100%+)
Default What version of MRX-4 is this?
I need some help, can the Mugen Guru ID this MRX4 is which version? The regular MRX4? Or MRX4R or MRX4X or....MRX3? Thanks a million
http://i146.photobucket.com/albums/r.../IMG_0993a.jpg
http://i146.photobucket.com/albums/r.../IMG_0991a.jpg
http://i146.photobucket.com/albums/r.../IMG_0994a.jpg
http://i146.photobucket.com/albums/r.../IMG_0996a.jpg
http://i146.photobucket.com/albums/r.../IMG_0997a.jpg
Old 03-15-2009, 12:25 PM   #1533
RCRjuanabbe's Avatar
long shock body inherent to a 4x, #4 wrench on turnbuckle ends says 4x-r.
eliminate the MRX3 concept. I have both 4X and X3.
RCRjuanabbe is offline   Reply With Quote
Old 03-15-2009, 12:31 PM   #1534
Trader Rating: 293 (100%+)
This looks like the MRX-4R. Long shock body in the rear and straight upper arms in the front. But the upper rear arms looks from the regular MRX-4 though. Might have been converted.
rcdoktor2 is offline   Reply With Quote
Old 03-15-2009, 12:39 PM   #1535
aturbotony's Avatar
It's a MRX4-R
Tony Thompson / Mugen Seiki USA / RC America / Airtronics / Flashpoint Fuel / Novarossi USA /Jgo paints / DeSoto Racing/ Murnan Modified Motors / Zac Project Tires / My Wife and Kids /
aturbotony is offline   Reply With Quote
Old 03-15-2009, 12:48 PM   #1536
It's a MRX4-R.
JASON MAC is offline   Reply With Quote
Old 03-15-2009, 01:58 PM   #1537
wingracer's Avatar
Trader Rating: 24 (100%+)
Yep, R. It looks like an R front shock tower, R uprights with no shims on the axles and R rear shocks and tower.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-15-2009, 02:37 PM   #1538
The brake lever looks very short. That part could be from the x kit.
fulcrum2 is offline   Reply With Quote
Old 03-15-2009, 02:40 PM   #1539
wingracer's Avatar
Good eye, that is an X brake arm.
Team Shepherd USA
Old 03-15-2009, 02:53 PM   #1540
lil-bump's Avatar
Trader Rating: 83 (100%+)
It has a R main chassis. It's a Mrx4-r. but it does have the X brake lever
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-15-2009, 08:33 PM   #1541
Guys...excellent information and now I know it is an "R" because you guys say so....thanks a million.
I have 1 more question, I do not have the manual of this car....is there anywhere I can download the official MRX4R manual? Like Mugen Seiki website..?
Also...someone mentioned my car has the optional chassis, any place I can see this chassis listed as an option..?
I ran Serpent most of the time, this is my 1st ever Mugen....and how much of a different between the R and the X? I remember back then when X came out, ppl said it use back a lot of the MRX4 parts (like back to the basic)...I am not qute sure what was that mean....
Thanks again....
Old 02-06-2011, 01:28 PM   #1542
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Well I'm fresh back from the winter nats and I think I need to figure out how to shorten my rear wheel base. Without spending 2 days searching this thread for the how to, how much do I trim off the upper and lower arms?
I was having issues getting in and out of the sweeper going onto the straight if you wanna call it a straight away lol. I was lifting off throttle and turning in and when getting back on the throttle the back end of the car would try to step out on me. I was running -2 toe per side, -2 camber per side, 5.5 roll center, and about 3mm on the rear swaybar. 32 fronts and 35 rears. P909 body with the rear wing all the way up.
Thanks!
Lon
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
Old 02-06-2011, 10:18 PM   #1543
asw7576's Avatar
Thanks!
Lon
1. Cut 1mm on the lower suspension arms ( where you insert in the hinge pin). Please observed where and the direction to cut. You have to cut 4 arms @ 1mm each.
2. Buy tamiya wheel hex spacer 1mm thick ( red color ), and insert those spacers so front and rear lower suspension arms, they become closer ( shorter wheelbase by 2mm in effect ).
Isn't that shorter wheelbase will make your problem even worser ?
I think you should try these ideas for rear wheels : wider track width, lower downstop value ( 7 instead of 9 ), 3 degree toe in, 3.5 or 4 degree camber.
And check your rear brake for free wheeling, incase you have drag brakes on.
Old 02-07-2011, 06:57 AM   #1544
Dasmopar's Avatar
Thanks for the advice. The rear track is already really wide, I didn't try less droop, I kept adding and subtracting toe all week and that was not helping, at 2 camber my rear tires are wearing pretty close to perfectly flat. I run zero drag brake. I think lowering the rear roll center and shortening up the wheel base will help sense thats like lowering the rear of the car and putting more weight over the rear tires.
Lon Burling II
Old 02-07-2011, 07:45 AM   #1545
asw7576's Avatar
ooops, i mean wider front track width. ie. front.
or you can narrow rear track width by 1mm on each side.
or increase the rear wing even higher ( or buy ybslow H body post to increase the height of rear body even higher ).
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
