Old 07-18-2008, 08:24 PM   #1516
jeff1's Avatar
Questions??
Originally Posted by choisan View Post
From my terrible experience of 960's clutch, you may try to see your clutch endbell. If the inner part is grinded and scratched, sander it and make it smooth. Make sure it is not wobbled when you use your fingers to rotate it.
If this remains, change a new endbell. Mugen always have the best parts and it seldom happens. Good luck!
sorry didn't understand
what part are you referring? The one that clutch shoes hits to engage?
jeff
jeff1 is offline   Reply With Quote
Old 07-19-2008, 08:23 AM   #1517
choisan's Avatar
H0710 endbell
choisan is offline   Reply With Quote
Old 08-02-2008, 05:12 PM   #1518
getpip's Avatar
Default clutch
Hi
Can anyone tell me the difference between the MTX4 clutch and the MRX4 clutch.
The kits have different part numbers but some parts in common..
Would they be compatible?
Thanks Pip
getpip is offline   Reply With Quote
Old 08-02-2008, 05:28 PM   #1519
quietstorm76's Avatar
Originally Posted by getpip View Post
Hi
Thanks Pip
only parts that interchange are the clutch spring, fly weights, clutch shoe and the thrust bearings.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-03-2008, 09:56 AM   #1520
getpip's Avatar
Thanks .. no shortcuts there then!!!
Old 08-03-2008, 12:17 PM   #1521
jeff1's Avatar
choisan I found the problem... the inner part is scratched like you commented
I ordered a new clutch bell and hope to test soon. Will let you know
by the way
how do you set your gap and end-play?
Old 08-03-2008, 08:27 PM   #1522
choisan's Avatar
Pls try 0.5 gap and 1.0 spring press. After setting this, iwill put the car on road test to see if the punch is enough and any abnormal such as the clutch powder seen. If OK, i will tighten the spring load a quarter turn in, and test run, until i get the ultimate feeling that i like. Hope it works and enjoy it.
Use the Super Hard spring for Novarossi based engine. Ultra Hard- I was told, it works better with Ninja's engine
Old 08-03-2008, 08:34 PM   #1523
choisan's Avatar
and please do make sure the 4-pc centrifugal shoes, clutch and the clutch holding plate(is flat) are in good condition. To my experience, the endbell is the obvious one.
Old 08-11-2008, 05:58 AM   #1524
getpip's Avatar
Default Tyre cone
Hi people
Im a 1/8 newbie.
Can someone please tell me how much cone you guys true into a new set of tyres before use.
Old 08-11-2008, 01:22 PM   #1525
V12
V12's Avatar
Hi
I donīt own a MRX4R but I want using some spares for a certain application. Maybe someone could help me here with a question.
From the manual I saw the ballcups (H0855, H0858, C0111C) from steering rods, rollbars and shock mounting are used with the H0867 balls usually.
Those H0867 balls have a small shoulder above the ball what canīt be used for my need.
Now I saw at the rear suspension there is a different ball used for connecting the upper arm to the rear upright. This ball is H0180 and doesnīt have a shoulder.
Are the H0180 balls the same diameter as the H867 or in other words, is it possible using the H0180 balls on the H0855 or H0858 ballcups?
V12 is offline   Reply With Quote
Old 09-17-2008, 01:15 AM   #1526
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Hi,
I just picked up one of these for my first run in 1/8th scale......
Sworkz EVOII LE/Hobbywing/Protek
Roche Rapid F1/Hobbywing/LRP
Taffyjnr5 is offline   Reply With Quote
Old 09-17-2008, 08:29 PM   #1527
Woodlands Racer's Avatar
Hi people
Im a 1/8 newbie.
The rears are usually cut with 1-2 degrees of camber. The fronts are sometimes cut with 0-1 degree of camber. Best way is to get your set up on your car, put on a new set of tires all around, and then run a tank of fuel on your track and measure the camber (front and rear). You then will be better able to dial in what you need for that track or you can get local info from area racers in advance.
Good luck and enjoy,
Roger
Roger Bourland
The Woodlands, TX
THIRD COAST RACING
Max Power/RC America - Mike's Hobby Shop - SRC Tires/RC America
Getting Faster With Age, Hope to see many more birthdays!
Woodlands Racer is offline   Reply With Quote
Old 09-17-2008, 10:46 PM   #1528
asw7576's Avatar
Originally Posted by V12 View Post
Hi
H0180 balls have bigger diameter than H0855 & H0858.
H0180 balls wont fit into C0111C plastic connectors.
Try Kyosho ballcups,
I think they have the balls without the shoulder. ( I don't know the part number ).
Old 09-22-2008, 04:33 PM   #1529
getpip's Avatar
Roger
Thanks Roger
Im off to run in my new engine 2moro an SHXT2 with ceramic piston ready for my first 1/8 meeting this weekend.......
YIKES!
Old 10-16-2008, 10:41 AM   #1530
wmay11's Avatar
Hi guys, how do the GRP tuned motors run compared to the Ninja line? I read that the people love the Ninjas, is the GRP the same motor?
wmay11 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
