Old 06-24-2008, 06:52 PM   #1501
quietstorm76's Avatar
Originally Posted by onerun View Post
Has anyone else experienced losing a rear out drive bearing and the concentric adjuter? It's happened twice now. It gets rather expensive, considering it deforms the hole in the rear bulkhead, rendering it useless.....as well as ruining the rear belt.
Doc
Sorry dude but no I haven't. Check for a bind, or lube the bearings every race day.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 06-24-2008, 06:55 PM   #1502
Originally Posted by bobbyblaze View Post
ok cool , right now this my first 1/8th scale, kinda new to the onroad scene, but i have a shadow body is it ok?
The only body I run is the Central. Hands down the best body for the MRX4R IMO. Second choice would be the Parma R-11.
Primary Weapon: ?
Secondary Weapon: ?
Old 06-24-2008, 08:42 PM   #1503
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
one last question ...who make the Central
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 06-24-2008, 08:50 PM   #1504
Serpent does sort of. Go here
gasrccar.com
Primary Weapon: ?
Secondary Weapon: ?
Old 06-24-2008, 09:01 PM   #1505
bobbyblaze's Avatar
cool ...good looks... now i need to find a setup station
Old 06-25-2008, 05:48 AM   #1506
choisan's Avatar
It is by CentralRC from Japan. http://www.centralrc.co.jp/
choisan is offline   Reply With Quote
Old 06-25-2008, 09:19 AM   #1507
Other then the notorious tip breaking off, has anyone got anymore feed back on the Mugen FLS 2632? run time? other motors running them? top end? bottom end? low end? ect ect...
much appreciated
Baedarlboo is offline   Reply With Quote
Old 06-28-2008, 10:19 AM   #1508
lil-bump's Avatar
Trader Rating: 83 (100%+)
Giving 1/8 scale a try. Is it normal to cut camber into the tires? Or should I cut them straight across. Any advice would be greatly appreciated.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-28-2008, 12:49 PM   #1509
Winner's Circle's Avatar
Pass you soon...
Most people do cut a little camber angle into the tires.
Lee
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 07-01-2008, 08:27 AM   #1510
bobbyblaze's Avatar
when i run my car i notice when i hit the brakes the sort of ver to the right, i try adjusting the trim on the radio but still do the same is that common on the mrx4r & what can i do to fix it?
Old 07-01-2008, 10:14 AM   #1511
RC-ProSpeed's Avatar
That's due to the front oneway, try adjusting the brakes to don't hit that hard, or if you have a radio with the anti lock function set it up right so you can have brakes with out locking the tires.
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 07-03-2008, 03:56 AM   #1512
asw7576's Avatar
Feel bored last night......... I'm cutting 1mm at the rear suspension arms to make 1mm shorter wheelbase. Let see the impact on sunday.
( i guess the impact is small..... )
Old 07-03-2008, 07:04 AM   #1513
try cutting 3mm. You would have to take off from the bulkhead also. Use the same kind of spacer as the front.
Old 07-16-2008, 06:18 PM   #1514
jeff1's Avatar
Questions??
Hello
How you guys set your clutch?
I'm following the Josh Cyrul method in my Triple R and the clutch works awesome
I tried this method in MRX4 but the yellow shoe wears very very fast, I ran only 1 Liter and I already can see the flywheel pins!!
What are initial settings for gap and end-play? In Mugen setting sheet says cleareance, what is this? Gap or End-play
Spring pre-load is 1.2mm with MSR hard spring
Gap 0.4mm measure without inner bearing, I shim in thrust retainer
End-play with everything installed 0.2mm
jeff1 is offline   Reply With Quote
Old 07-17-2008, 06:12 AM   #1515
choisan's Avatar
From my terrible experience of 960's clutch, you may try to see your clutch endbell. If the inner part is grinded and scratched, sander it and make it smooth. Make sure it is not wobbled when you use your fingers to rotate it.
If this remains, change a new endbell. Mugen always have the best parts and it seldom happens. Good luck!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
