Mugen MRX-4R
#1486
Hey guys
A buddy of mine has a mrx-4r he needs to put up 4sale...Its a roller with tires, battery and a pipe. He drove it a hand full of times. He basically bought it because he wanted something fast and since we dont have a 1/8th scale track near us it got old fast.
How much can he get for something like that? Thanks for the help.
#1492
MRX4R
Set the front body right at 12mm from the front bumper.
You can get the plastic screws from Frys electronics in the computer section.
I use these for the rear floating body mount, and also for the body stiffners.
A lot of drivers use pop rivets for the body supports, but I like the light weight plastic screws.
#1497
MUGEN MRX4R
The Frisbee is not much better either.
For the Mugen, the Central, R11, or even the new Blitz <very close to the Central>
I bet I have only seen 3 to 4 Shadow bodies being used at all of the practices, and races I go to, which is every weekend.
If you were close enough to where I run, I would let you try the Central, R11, and the Blitz and compare them to the Shadow.
You can just "play" with the Shadow, but do yourself a favor, and dont try and dive into the corners with it, because you will wind up on the outside wall without a doubt.
I must have close to 60 bodies now, and they are all either the Central,or R11,with one Shadow, and one Frisbee.
#1498
Either the Central, or the R11 work the best on the Mugen.
#1500
MUGEN MRX4R
For the rear floating body mount, take the mount with you and you will be able to find the correct screw to thread into it. I dont remember the exact thread. They will fit tight, and should fit tight so they will not vibrate loose.
For the side stiffiners, they make many, many different sizes. I use a plastic scew that is about 1/8" x 1" long. The nuts for the screws are sold seperatly, so make sure you get the same threads. I have tried pop rivets, and to me they are a pain compared to these plastic screws
