Old 05-16-2006, 12:49 AM   #1
Joe Os's Avatar
Default Which Glowplug best for hot weather
Which Glow plug best for hot weather? and why?
Joe Os is offline   Reply With Quote
Old 05-16-2006, 08:34 AM   #2
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Unanswerable , every engine is different.
Artificial-I is offline   Reply With Quote
Old 05-16-2006, 08:34 AM   #3
ziggy12345's Avatar
A hot plug will ignite the mixture sooner and so advance the timing for low end power while a cold plug the opposite. In hot weather the air is thinner and so you dont get the pressure in the engine to ignite the mixture as soon as when its cold. You can run a hotter plug to compensate.
So.... Hot weather = Hot plug. Cold weather = cold plug
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 05-16-2006, 11:04 AM   #4
Joe Os's Avatar
I wonder why, when i run my car during night time. It runs perfect when im using very cold plug during night and the other day we run again day time my car wont run that good as night time. Maybe thats the reason why i run like that bec. I didnt change the plug everytime run (I use plug same day & night) lol. Salamat bro
Old 05-16-2006, 11:26 AM   #5
Moderator
Night Time is cooler = denser air = more oxygen = leaner air mixture and more effective cooling.
All equaling more power. Engines love cool air.
Old 05-16-2006, 12:08 PM   #6
Joe Os's Avatar
Which one the best to run? nigh or day?
Old 05-16-2006, 12:21 PM   #7
Moderator
All plugs are different. If your asking for which heat range is best , then someone already answered that. Not sure if its correct but otherwise I find glow-plugs you just gotta play with and see the results for yourself.
Mainly what you have at your lhs is what you get to choose from and you go from there. I do order some plugs but only for specific reasons and or when I found a plug I personally like.
Plugs are just like fuel and anything else. Its what you can get and what you like , what runs well with your motor etc.
Old 05-16-2006, 12:29 PM   #8
Joe Os's Avatar
Salamat bro.
Old 05-16-2006, 12:43 PM   #9
Joe Os's Avatar
Whats the defference bet. Short or long body plug? And why?
Old 05-19-2006, 09:28 AM   #10
I believ longer glowplugs are for turbo engines. According to what I have read, do NOT use a turbo glow plugs in a non-turbo motor and vise versa. This could cause serious damage
dohc91crx is offline   Reply With Quote
Old 05-19-2006, 10:33 AM   #11
think of plugs as a way to tune a motor , hot plugs tend to advance
the timeing, cold ones less so, .12 tend to run best with hot ones
.21 best with medium to cold, short twisty tracks hotter plugs
long hi speed tracks cold , hot plugs need a little richer setting
with cold plugs a little bit more forgiving when you lean the motor out
michael 1 is offline   Reply With Quote
Old 05-19-2006, 10:44 AM   #12
E.T.'s Avatar
yeap, that's something i don't understand too. That are 2 different kinds of turbo plugs in the market. The long body & short body ones.... anyone knows???
thanks.
E.T. is offline   Reply With Quote
Old 05-21-2006, 03:58 AM   #13
ziggy12345's Avatar
thanks.
Long body has move volume inside the plug so retards the timing slightly. It makes the plug slightly colder hence the name on the novarossi plugs
C6TGF is a 6 wire plug with a long body (Freddo for cold in Italian)
C6TGC is a 6 wire plug with a short body (Caldo for hot in Italian)
I always use the Cs
Sponsored by:
Norfolk and Chance
Old 05-21-2006, 07:30 AM   #14
Moderator
A long plug also increase compression.
Old 05-21-2006, 09:42 AM   #15
E.T.'s Avatar
I always use the Cs
Oh.. i understand it now. Thanks.
Mugen Ninja .12 Glowplug V for Victory Onroad Nitro Engine Zone 13 06-23-2010 08:40 AM
glowplug for b7 pro j_griffis90 Nitro Off-Road 6 09-25-2007 12:40 AM
Mugen X12 glowplug question snowboardgeek1 Onroad Nitro Engine Zone 28 08-04-2005 07:15 AM
Hkosho GS21r glowplug Mick Matthews Onroad Nitro Engine Zone 0 08-07-2004 06:22 PM
What Glowplug For Sts Turbo - 25% Fuel deanspoors Nitro On-Road 2 01-11-2003 08:45 PM
