Which Glowplug best for hot weather >
Old 05-21-2006, 04:19 PM
  #16
ProudSavageOwnr's Avatar
Originally Posted by E.T.
Oh.. i understand it now. Thanks.
lol no worries man
ProudSavageOwnr is offline
Old 05-21-2006, 04:44 PM
  #17
itchy b's Avatar
Originally Posted by Artificial-I
A long plug also increase compression.
would'nt it decrease compression because of the slightly larger volume inside the glow plug?
itchy b is offline
Old 05-22-2006, 01:22 AM
  #18
ziggy12345's Avatar
Yes as turbo plugs seal at the bottom so it will give you more cylinder volume
Cheers
ziggy12345 is offline
Old 05-22-2006, 03:59 AM
  #19
Artificial-I's Avatar
Trader Rating: 17 (100%+)
In comparison to a shorter plug, the longer reach plug will go deeper into the combustion chamber , therefore increase compression , even though the area inside the plug has more volume , the walls around that area also increases and open air that was already open its now just taken up by more metal. So the compression increases.
Artificial-I is offline
Old 05-22-2006, 05:57 AM
  #20
ziggy12345's Avatar
A turbo plug does not enter the cylinder, it seal at the bottom so this is not correct.
Old 05-22-2006, 06:06 AM
  #21
Thought we were talking about regular. Then your right , it will stand higher so less compression on turbo plug long. It also doesnt seal from the bottom , but the sides as it tapers or cones.
Old 05-22-2006, 06:26 AM
  #22
hav_lova's Avatar
Medium plug comes out the winner all the time
hav_lova is offline
