-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   Low engine mount for kyosho gt2? (https://www.rctech.net/forum/nitro-road/1140205-low-engine-mount-kyosho-gt2.html)
Zeelott 02-28-2026 02:58 PM
Hi i have a kyosho gt2 which I just bought a new bump start motor for. I want to know is there a set of mounts that will lower the motor more than the stock mount that is on there so the flywheel can reach the starter wheel better? Any help is greatly appreciated.
Bud 02-28-2026 05:09 PM
I'm not sure about your gt2 but on an rc10gt the pull start motor mounts are a couple mm taller so the pull start clears the chassis. You might just need the stock non pull motor mount.
