Old 05-07-2006, 02:18 PM   #1
Default adjusting downstops without droop gauge
I do not have a droop gauge to measure downstop settings
are there any other good ways to do this?
impulsed is offline   Reply With Quote
Old 05-07-2006, 03:01 PM   #2
itchy b's Avatar
you can set the droop using your ride hieght guage but first take the wheels off and put the car on a flat surface[ table,setupboard ] to make sure chassis is straight and flat, then using r/h guage adjust distance betweentable and bottom of hubbs from one side of car to the other. once this is done put the wheels on and set your ride height. then using your guage starting at one end at centre of chassis lift car up to the point where both wheels are just touching the table (make sure both wheels lift off table together) measure it there and the difference r/h and this measurement will give you a good starting point from where you can set it to where it works best for you . same method for the front but take bumper off to easily measure from front of chassis.i've used this method but its a little bit more acurate with d guage, once you first set front and back up if you need to adjust droop you can do this making sure you make equal adjustments from left to right (1/4 turn left and right saves removing bumper all the time
hope this helps you out a bit
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
downstops and droop stephen hilton Electric On-Road 8 04-10-2007 09:06 AM
Droop Blocks and Gauge RED-LINE M03 R/C Items: For Sale/Trade 6 05-22-2006 05:42 PM
Droop Gauge LosiSuperTruck R/C Items: Wanted to Buy 1 09-14-2005 07:53 AM
MATT FRANCIS Set-up Board,Integy Droop Gauge&Hudy Ride Height Gauge olewarrior R/C Items: For Sale/Trade 5 05-23-2002 08:23 AM
Matt Francis Set-up Board,Integy Droop Gauge&Hudy Ride Height Gauge F/S olewarrior R/C Items: For Sale/Trade 3 04-26-2002 03:10 PM
