Old 05-02-2006, 08:48 AM   #1
Default keep loseing control
hi can anybody help ive got a on road nitro car ive set the stearing all stright it goes stright at low ish speed but as soon as i full throtle its all over the place it goes to the left and right its got slicks on at the moment i tryed it with foam tyres that dint make a differance olso has any body any tips the nuts on the wheels keep getting lose THANKS DANNY
1615danny is offline   Reply With Quote
Old 05-02-2006, 09:34 AM   #2
onnetz's Avatar
more info would be helpful.......
kit, engine, surface, body.....
some possibles.....
too much power.. seen it many times.. I can't control my hpi with a .18.. duh.
slop in the car,
too weak of a steering servo,
binding somewhere,
bad diffs...
as for the tires, I've had better luck on any surface with foams over rubber.
onnetz is offline   Reply With Quote
Old 05-02-2006, 09:54 AM   #3
ITS A YOKOMO GT4 I USE IT AT THE TRACK IVE JUST LOWERED IT WILL THAT HELP
Old 05-02-2006, 10:08 AM   #4
onnetz's Avatar
whats everyone else running at the track?? foams or rubber..
lowering it can help or make it worse..
if its too low then the chassis will hit the ground causing the weight to shift.
when it starts getting out of control, is it wandering or does it feel twitchy?
by wandering I mean does it seem to randomly go here and there..
by twitch I mean is it seem like the steering it too sensitive....
Old 05-02-2006, 03:47 PM   #5
it seems to just go to the side (both sides) it just seems to do its own thing the steering olso does feel too sensitive you just tap slightly and your off/they seem to be on foam/ i put foam on but it still seems to go off the track i then lowerd it but havent tested it
http://halifaxtrack.co.uk/hfx/
THANKS
Old 05-02-2006, 03:53 PM   #6
onnetz's Avatar
THANKS
check the steering for excessive play. also sounds like you need a better setup..
first thing I would do is go back to foams.
Old 05-02-2006, 04:03 PM   #7
when i tighten the f wheels theres a really little wobble on both is that normal the cars is almost new
thanks
Old 05-02-2006, 05:35 PM   #8
onnetz's Avatar
thanks
a little is ok but really you want as little as possible.
how much play is in the steering without moving the servo?
did you, build the kit new, got it rtr, bought used?
I dont know much about that car, but usually stock setups are pretty good.
Old 05-03-2006, 01:30 AM   #9
it was an rtr 1 month old ivr got a big hole in the shell theres no roof can that cause to much drag/thanks for your help
Old 05-03-2006, 10:04 AM   #10
Send a message via Yahoo to mykel chua
well id suggest you get a good servo for steering (high speed and high torque servos would be good) My friend had this problem before but when we changed it to a high speed/torque servo, boy did it handle well.
mykel chua is offline   Reply With Quote
Old 05-03-2006, 10:17 AM   #11
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Make sure all 4 wheels are driving the car. Are all the axles, belts dogbones, driveshafts etc on the car. It really sounds like you are running on 2 wheel drive.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-03-2006, 10:50 AM   #12
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Sweet track Danny!
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-03-2006, 10:58 AM   #13
captian's Avatar
now thats really nice
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 05-03-2006, 11:07 AM   #14
duneland's Avatar
What track is that? Where?
duneland is offline   Reply With Quote
Old 05-03-2006, 11:28 AM   #15
teammpp's Avatar
Its the Halifax track in the UK. Thats where last years European Championship were held.
teammpp is offline   Reply With Quote
*****INDI 16X908 Climate Control Charger with Thermo Control Stand - 180.00 Shipped* dgullickson R/C Items: For Sale/Trade 65 09-08-2008 09:40 PM
*****INDI 16X908 Climate Control Charger with Thermo Control Stand******* dgullickson R/C Items: For Sale/Trade 35 06-04-2008 07:12 PM
Integy 16X908 Climate Control Charger & 16X908 Thermo Control Stand Tres R/C Items: For Sale/Trade 7 02-21-2007 04:33 AM
cant control my car!!! fez Rookie Zone 3 01-31-2006 02:52 AM
car out of control! RCMASTA Electric Off-Road 4 01-07-2006 04:10 PM
