Old 04-30-2006, 03:05 PM   #1
32819toon's Avatar
Default CONVERSION
Hi,
I have a Kyosho V One rolling chassis which I would like to convert to an off roader. What parts would I need for this ? Would they mainly be suspension parts ? What is the difference in wheelbase between an on road car and an off roader ? Also, Is there a suitable VW Beetle / Bug bodyshell available for this car.
Thanks,
32819toon
32819toon is offline   Reply With Quote
Old 04-30-2006, 08:44 PM   #2
fritzD's Avatar
Send a message via Yahoo to fritzD
why would you do that? you'd be better off buying an Off road car.
fritzD is offline   Reply With Quote
Old 05-01-2006, 03:25 PM   #3
32819toon's Avatar
Default Conversion
Hi again,
Thanks for the advice. I am thinking about this as I bought the car very cheaply and want to do something with it. I am not wanting to turn it into a monster truck, just something to use on grass and dirt track. I want to lift the height up and put some off road wheels on. I also like off roaders with Beetle bodyshells on. I just want to have a bit of fun with it with the kids.
Thanks again,
32819toon
Old 05-01-2006, 04:15 PM   #4
Trader Rating: 16 (100%+)
Originally Posted by 32819toon
Hi again,
Thanks again,
32819toon
Just mount the KYOSHO type off road rim with off road tires (the bigger you have, the higher above ground).....then, you will need to custom made 2 shock mounts, one front one rear....actually, they need to be taller.......then get a full set of off road shocks (any brand).......then there you go.
I doubt you can get the off road longer arm, drive shaft or CVD that is direct convert onto your V1R...........
Oh...and I am sure it will handle horrible........but at least you can run it on some short grass lawn.........like your backyard. And don't try to jump....
Old 05-01-2006, 04:30 PM   #5
onnetz's Avatar
with larger tires your going to need to change the gearing.....
onnetz is offline   Reply With Quote
Old 05-01-2006, 09:06 PM   #6
fritzD's Avatar
yes, indeed. Or else, your belts will get all the stress and break easily.
Old 05-02-2006, 01:07 AM   #7
32819toon's Avatar
Hi,
Thanks for the advice guys.
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
RPM conversion RCB3 R/C Items: Wanted to Buy 0 09-14-2005 08:05 PM
