Old 04-28-2006, 07:23 AM   #1
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Default Overgearing
Does anyone run with there front overgeared (front spinning faster than rear) and what track conditions and type (tight and twisty or open) would this suit. Thanks
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Old 04-28-2006, 07:44 AM   #2
itchy b's Avatar
Taffyjnr5
if by that you mean changing the side pulley for one with 1 less tooth, its actually almost 1.1 drive front to rear,and would suit a small to medium track with low traction. you can use same diameter all round like this or maybe 1mm larger on the back . in low traction conditions it gives you better traction in rear when you gas it and tyre wear is much more even good luck and enjoy
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 04-29-2006, 12:36 PM   #3
asw7576's Avatar
Taffyjnr5
technically it is call front overdrive.
front overdrive is good for low traction track.
the downside are rear tires wear faster and possibility of strained middle belt when front overdrive is too extreme.
racers usually use 2mm - 3mm split between front and rear tires ( smaller front dia. ).
Old 04-29-2006, 12:41 PM   #4
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I routinely run front overdrive. What it does is give more on power steering. It allows me to really accelerate through turns. It give more corner exit speed. Many cars as you accelerate out of a turn tend to push as weight transfers to the rear. With the front turning faster than the rears it tends to reduce rear squat as well as pull the car throught the turn.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-29-2006, 10:57 PM   #5
itchy b's Avatar
is this with using a 24 tooth or 23 tooth gear for side belt
EX1.5-SC10 4x4
Old 04-29-2006, 11:58 PM   #6
You can get front overdrive with any front pulley. On an MTX4 with a 24t front pulley you will start getting front overdrive when your split is between 2 - 2.5mm. (If my memory serves me right). I would never consider using a 23t pulley on the MTX4 unless you want a lot of front overdrive.
There is an overdrive chart on mugen japans website.
www.mugenseiki.com
Click on english, then on the right side.... setting sheets. You will see all kinds of sheets including the overdrive chart.
Old 04-30-2006, 02:37 AM   #7
asw7576's Avatar
Taffyjnr5
What car is yours ?
Old 04-30-2006, 05:08 AM   #8
Taffyjnr5's Avatar
I have just started in Nitro (raced electic for 2 years) and I am running a Hobao GPX-4 Pro/O.S. Thanks
Taffyjnr5
Old 04-30-2006, 06:21 AM   #9
itchy b's Avatar
www.mugenseiki.com
thanks scott, my mistake, next time i'll pay closer attention to how many teeth my over drive chart tells me are there hehehe and looks like i mixed up which pulley did what too sorry about that , back to school for me
EX1.5-SC10 4x4
Old 04-30-2006, 06:28 AM   #10
Send a message via MSN to ickvanovs
can you explain a bit more, why is it good for low traction track ?
ickvanovs is offline   Reply With Quote
