Old 04-10-2007, 05:28 PM   #1456
Trader Rating: 13 (93%+)
Default thinking of buying rrr evo..
hey guys i currently have a rrr with rrr evo shocks..
would it be worth upgrading to the rrr evo as a second car?
i mainly race on high grip tracks and the current rrr is working real good
it is about a year old but i regularly replace parts.
the rrr evo is pretty cheap over in japan now to
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-10-2007, 05:44 PM   #1457
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by rmdhawaii
There is 2 versions one is with the pins & the other is a solid spool lightweight that is exactly like the Km the only thing it uses a grub screw instead of pins
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-10-2007, 06:11 PM   #1458
rmdhawaii's Avatar
No wonder I couldn't find it - it's a G4 part.
Does anything special need to be done to fit this in the RRR????
BTW.. Thanks George.
K1477 G4 Alum. Front Solid Axle Set
http://www.kfactoryracing.com/produc...1477&pageNum=1
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-10-2007, 07:03 PM   #1459
what makes the new shocks better than the old one's? also what shock end are you using, short, medium, or long?
bosfan is offline   Reply With Quote
Old 04-10-2007, 11:08 PM   #1460
nikoskar's Avatar
If i am correct the Evo WC has Evolva's front shocks
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 04-11-2007, 12:35 AM   #1461
MRX4-R03's Avatar
but what is the difference in the shocks, the only difference is that you have more springs you can use..
MRX4-R03 is offline   Reply With Quote
Old 04-11-2007, 02:35 AM   #1462
rmdhawaii's Avatar
http://www.rctech.net/forum/showpost...postcount=1305
Old 04-11-2007, 06:26 AM   #1463
Eric Gebhard's Avatar
One thing that no one has mentioned is that the shock pistons are quite different from the RRR WCE and the RRR EVO. The front pistons in the WCE shocks are have one 1.3mm hole and and the rears have two 1.0mm holes. On the EVO both the front and rear pistons have two 1.1mm holes. Fortunately the inside diameter of both shocks is the same so you can put the EVO pistons (p/n FM530-3) in the WCE shocks without any problems. One other difference to mention is that the new shock bodies are about 2mm longer than the WCE bodies. How much this affects performance I don't know but it is a difference that should be noted.
If you are thinking about upgrading the shock here are the parts that you will need:
Shock Body p/n FM529-1
Shock Collar p/n VZ109 (this is the servo saver collar)
Piston p/n FM530-3
Front Spring p/n VZ242-4517
Rear Spring p/n VZ243-5017
Shock Ends p/n FM509B (this parts tree has the shock end on it)
Mugen shock ends will also work.
Eric Gebhard is offline   Reply With Quote
Old 04-11-2007, 10:19 AM   #1464
Anyone did use rear tire for the front?
www.rc-ms.com
Big_ants is offline   Reply With Quote
Old 04-11-2007, 10:22 AM   #1465
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Piston p/n FM530-3
Good info. to know.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 04-11-2007, 02:58 PM   #1466
GMartinez's Avatar
Piston p/n FM530-3
It will be easuer to buy the whole shock kit since you forgot to mention the shock shaft is titanium. As for the new shocks one major difference is that the old shock s when tighting the cap most of the time if you went to hard it would pinch the bladder & you would have to redo them again the new shocks are more consistent on rebuilding them
Old 04-11-2007, 03:00 PM   #1467
GMartinez's Avatar
Yes you are correct
Old 04-11-2007, 03:02 PM   #1468
GMartinez's Avatar
they actually have one that states on the package g4 /V1RRR it works for both the difference is that were the bearrings sit it is milled out more than the one that is pictured & they are hard to come by I am in search of one I have the same one & im trying to locate a machine shop that can mill it for me since the sent me the wrong one it is shy by .25mm on both ends 7 I forgot to mention it is titanium i will try to post a pic if I can get the diggy to work
Old 04-11-2007, 03:06 PM   #1469
GMartinez's Avatar
You could of asked I would of gave you the link but I made you look
Old 04-11-2007, 06:37 PM   #1470
Grassy's Avatar
i ran the blue k-factory one in my G4S it was fantastic had no wear in the cups after 9 months of racing i still have it i wasnt sure if it fit in the RRR or not. The spool that Tosolini and Shimo were running at the worlds were out of the V1S-III the plastic one
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
