Old 03-25-2007, 05:11 PM   #1381
bvoltz's Avatar
Trader Rating: 44 (100%+)
Can someone tell me how to select gears that work together...
This weekend I wreched a number of gears before I tried a larger on the second speed and figured out my problem was I was running a 55 and I should have been running a 56.
So how do I figure out what gears to run with other gears.
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 03-25-2007, 09:02 PM   #1382
nitro_moe's Avatar
An easy way to do it is to add both first pinion and spur gear size together and note the outcome. Then match it with second gear while noticing the jump between pinion and spur.
For example, a stock RRR comes with 1st pinion 16 and 1st spur 61, 2nd pinion 21 and 2nd spur 56. 16+61= 77, 21+56= 77
note that the difference between both pinions and both spurs is 5. As long as you keep an equal difference between both spurs and pinion then you should be fine. Just bear in mind that smaller pinions go for first gear and higher for second. The opposite applies to spur gears (higher for first and lower for second)
Hope I didn't bore you with my explanation..
nitro_moe is offline   Reply With Quote
Old 03-25-2007, 09:33 PM   #1383
bvoltz's Avatar
No you did not bore me with your explanation..
Thank you very much... this helps a lot...
I feel really stupid asking this question and the I did not know about this... It would have save me a lot of gears this weekend...
It was by luck I burn all my 55 gears and had to use a 56, which was the one I should have been using in the first place....
Old 03-26-2007, 02:00 PM   #1384
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Lightbulb TEST
****TEST Post Only****
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 03-26-2007, 02:20 PM   #1385
Derby Bros Racing's Avatar
Well you could have asked a question or something. I know you can do better than test post! just kidding
Derby Bros Racing is offline   Reply With Quote
Old 03-26-2007, 02:40 PM   #1386
I've never had a problem with matching gears, I thought all the combinations worked together?
pitbits is offline   Reply With Quote
Old 03-26-2007, 03:21 PM   #1387
bvoltz's Avatar
Not me... I was stripping spur gears up this weekend... what made me figure it out, I ran out 55 spur gears, and had to use a 56, which that was the correct match on total number of teeth (no teeth jokes about MS ) for first gear total to second gear total... I was off by one and I tore up 4 55 gears, and 2 61 gears... because of this... At first I thought it was the new steel gears I had put on... but that was not the problem, it was the total count.
Speaking of pinion gears, does anyone know of a good gear caddy, I really hate counting them out...
Old 03-26-2007, 10:46 PM   #1388
Default The screws that come with the kit
Does the V One RRR EVO WC kit come with socket head screws or phillips head screws, just wondering if i should go ahead and assemble the kit with this set https://www.tonysscrews.com/displayP...5&categoryId=2
Dowg is offline   Reply With Quote
Old 03-26-2007, 11:04 PM   #1389
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
That kit comes with phillips head screws.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-26-2007, 11:14 PM   #1390
MCRUZ's Avatar
Talking speedline
scott, great job this past weekend!!! not bad with a new car
M32EVOX
MCRUZ is offline   Reply With Quote
Old 03-26-2007, 11:27 PM   #1391
JRRobiso's Avatar
Arrow
Will ask questions when building the kit. Need to get the stuff needed to run the car (starter box, additional servo for throttle/brake & the rest).
You just had to say something about my post.
Jo, I'll call or email you if I need your expert ( ) advise right away.
Old 03-27-2007, 12:37 AM   #1392
rmdhawaii's Avatar
Tony's screws are a good choice.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-27-2007, 12:46 AM   #1393
carkillaii's Avatar
Fish How Did You Do This Weekend?
carkillaii is offline   Reply With Quote
Old 03-27-2007, 08:08 AM   #1394
jarnotrulli's Avatar
i couldnīt get the kawahara or 3 racing in the netherlands brace i maked one myself from 3mm carbon i think it lookes pretty nice.
jarnotrulli is offline   Reply With Quote
Old 03-27-2007, 10:28 AM   #1395
I qualified 8th. I was running 4th when I moved over to let the leader pass and got my car into the marbles. I proceeded to run the car almost full speed into the wall at the end of the straightaway breaking the left front upright. The car is good. The team is great.
.... Thanks Marc...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
